in the Gateway Settings i set several TAGs like
- Serial Number
- Manufacturer
why are these Tags are not transmitted in rxInfo via MQTT in device/events/UP
Is there a way to switch this on?
Thank you for your support
Hello!
The content of the data transmitted is defined by the events (Event types - ChirpStack open-source LoRaWAN<sup>®</sup> Network Server), as far as I know it is not possible to add nor modify fields in this packages, except, of course, the objectJson
