Using loraserver 2.6.0
The node is using LRWAN 1.2.1 firmware from STMicroelectronics.
The node is configured to use ADR on.
Everything starts fine and the node is using DR5. Over time, although the SNR is always high (8-9) the DR goes down and eventually to DR0. I see the network server sending the following messages repeatedly. It seems the network server is requesting the DR to be set to 5 but it is not successful.
Another doubt: if the network server never sends an adr request with req_dr=4 or 3, 2, 1, 0 (checked all logs), how can the node reach DR0 ?
Apr 04 21:36:11 y-server loraserver[1419]: time=“2019-04-04T21:36:11Z” level=info msg="gateway/mqtt: uplink frame received"
Apr 04 21:36:11 y-server loraserver[1419]: time=“2019-04-04T21:36:11Z” level=info msg=“rx info sent to network-controller” dev_eui=0101010101190003
Apr 04 21:36:11 y-server loraserver[1419]: time=“2019-04-04T21:36:11Z” level=info msg=“device gateway rx-info meta-data saved” dev_eui=0101010101190003
Apr 04 21:36:11 y-server loraserver[1419]: time=“2019-04-04T21:36:11Z” level=info msg=“device-session saved” dev_addr=017f5b61 dev_eui=0101010101190003
Apr 04 21:36:11 y-server loraserver[1419]: time=“2019-04-04T21:36:11Z” level=info msg=“adr request added to mac-command queue” dev_eui=0101010101190003 dr=0 nb_trans=1 req_dr=5 req_nb_trans=2 req_tx_power_idx=5 tx_power=0
Apr 04 21:36:11 y-server loraserver[1419]: time=“2019-04-04T21:36:11Z” level=info msg=“requesting device-status” dev_eui=0101010101190003
Apr 04 21:36:11 y-server loraserver[1419]: time=“2019-04-04T21:36:11Z” level=info msg=“pending mac-command block set” cid=LinkADRReq commands=1 dev_eui=0101010101190003
Apr 04 21:36:11 y-server loraserver[1419]: time=“2019-04-04T21:36:11Z” level=info msg=“pending mac-command block set” cid=DevStatusReq commands=1 dev_eui=0101010101190003
Apr 04 21:36:11 y-server loraserver[1419]: time=“2019-04-04T21:36:11Z” level=info msg=“pending mac-command block set” cid=RXTimingSetupReq commands=1 dev_eui=0101010101190003
Apr 04 21:36:11 y-server loraserver[1419]: time=“2019-04-04T21:36:11Z” level=info msg=“gateway/mqtt: publishing downlink frame” qos=0 topic=gateway/00800000a0002529/tx
Apr 04 21:36:11 y-server loraserver[1419]: time=“2019-04-04T21:36:11Z” level=info msg=“downlink-frames saved” dev_eui=0101010101190003 token=26224
Apr 04 21:36:11 y-server loraserver[1419]: time=“2019-04-04T21:36:11Z” level=info msg=“backend/gateway: downlink tx acknowledgement received” gateway_id=00800000a0002529
