ADR System Testing - Force DR up and down
We have enabled ADR and intend to send larger packets when possible.
Is there a good way to cause Loraserver to send ADR commands increasing and decreasing the data rate to a single device in order to perform an end-to-end test?
Would it be sufficient to assign the device under test to a device profile and then raise and lower the min/max data rate? Would those parameters cause a DR update on next connect?
Thanks!
