LoRa Server v2.7.0
Improvements
Gateway downlink timing API
In order to implement support for the Basic Station some small additions were made to the gateway API,
the API used in the communication between the LoRa Gateway Bridge and LoRa Server.
LoRa Server v2.7+ is compatible with both the LoRa Gateway Bridge v2 and (upcoming) v3 as it contains both the old and new fields. The old fields will be removed once LoRa Server v3 has been released.
Max. ADR setting
- Remove max. DR field from device-session and always use max. DR from service-profile.
