I do not see any difference when I switch between the Sodaq source and your source (looking at the LoRaHelper::convertAndCheckHexArray). In general, can’t you just set the AppEUI to 0000000000000000?
Note: at the device-side, you must set a valid AppEUI / JoinEUI. It is just that there is no need to configure this at the ChirpStack side.
There’s an additional parameter to allow AppEUI’s that are all 0.
With regards to setting the AppEUI to 0, do you mean in the device or in chirpstack? I am probably blind, but i don’t see an option for that in chirpstack.
So, by default (without my patch) the device’s code checks for that and it’s not allowed.
My patch works fine. I’ve been testing the device and all is ok. I would however like to avoid having a specific patch.
I don’t know enough about lorawan to know if this is just silly from the Sodaq implementation, of if it’s something that could also be fixed on the chirpstack side
You could also set it to any other (random) AppEUI / JoinEUI value. As long as you have not configured any join-server with that specific JoinEUI, it will not break anything.
I have been using the Sodaq tracker code before, and had no issues using it. I’m not sure if I set the AppEUI to 0000000000000000 or something random, but there was no need to make any code changes.
I think i tried setting it to something and then i think i wasn’t able to join, but i will check this.
For now, it’s clear that my fix should actually be applied to the device and that changing chirpstack for this doesn’t make sense. Thanks for the help!
