Hi All,
I have been looking around through this forum in the hope that i would find a solution to my problem.
I have been trying to do small changes in the source code and then compile the application server again. I have tried multiple methods, including docker.
It seems that when i try to docker-compose the application server, even without any modification to the source code, it is going good. But once I try to start (using docker-compose up), postgresql, mosquitto, etc are all starting fine but the application server itself it stopping without any error.
Please find below journal:
-- Logs begin at Mon 2021-12-20 00:03:54 CET. --
Dec 26 17:06:33 chirpstack-application-server[111591]: time="2021-12-26T17:06:33.537991367+01:00" level=info msg="gateway ping created" ctx_id=2d8e3270-d744-480b-b809-f71524cb0941 dr=60 frequency=60 gateway_mac=a840411dae204150 id=604597
Dec 26 17:06:33 chirpstack-application-server[111591]: time="2021-12-26T17:06:33.590443614+01:00" level=error msg="send gateway ping error: store mic lookup error: set mic lookup error: dial tcp 127.0.0.1:6379: connect: connection refused"
Dec 26 17:06:34 chirpstack-application-server[111591]: time="2021-12-26T17:06:34.594730316+01:00" level=info msg="gateway ping created" ctx_id=273babea-e656-42d5-96fd-de6c19695ad8 dr=60 frequency=60 gateway_mac=a840411dae204150 id=604598
Dec 26 17:06:34 chirpstack-application-server[111591]: time="2021-12-26T17:06:34.696076845+01:00" level=error msg="send gateway ping error: store mic lookup error: set mic lookup error: dial tcp 127.0.0.1:6379: connect: connection refused"
Dec 26 17:06:35 chirpstack-application-server[111591]: time="2021-12-26T17:06:35.700491448+01:00" level=info msg="gateway ping created" ctx_id=f4808e1b-5e90-4b02-876a-5211ceb8200d dr=60 frequency=60 gateway_mac=a840411dae204150 id=604599
Dec 26 17:06:35 chirpstack-application-server[111591]: time="2021-12-26T17:06:35.792143972+01:00" level=error msg="send gateway ping error: store mic lookup error: set mic lookup error: dial tcp 127.0.0.1:6379: connect: connection refused"
Dec 26 17:06:36 chirpstack-application-server[111591]: time="2021-12-26T17:06:36.796841792+01:00" level=info msg="gateway ping created" ctx_id=6448fb0e-8d8f-484d-abfe-9c92255033ee dr=60 frequency=60 gateway_mac=a840411dae204150 id=604600
Dec 26 17:06:36 chirpstack-application-server[111591]: time="2021-12-26T17:06:36.871255233+01:00" level=error msg="send gateway ping error: store mic lookup error: set mic lookup error: dial tcp 127.0.0.1:6379: connect: connection refused"
Dec 26 17:06:37 chirpstack-application-server[111591]: time="2021-12-26T17:06:37.875207978+01:00" level=info msg="gateway ping created" ctx_id=ea355479-6e1c-49d6-a901-924ec0ffc410 dr=60 frequency=60 gateway_mac=a840411dae204150 id=604601
Dec 26 17:06:37 chirpstack-application-server[111591]: time="2021-12-26T17:06:37.94372946+01:00" level=error msg="send gateway ping error: store mic lookup error: set mic lookup error: dial tcp 127.0.0.1:6379: connect: connection refused"
Dec 26 17:06:38 chirpstack-application-server[111591]: time="2021-12-26T17:06:38.947473877+01:00" level=info msg="gateway ping created" ctx_id=b2883bdf-045b-4178-8c17-6f5f99906798 dr=60 frequency=60 gateway_mac=a840411dae204150 id=604602
Dec 26 17:06:39 chirpstack-application-server[111591]: time="2021-12-26T17:06:39.009486985+01:00" level=error msg="send gateway ping error: store mic lookup error: set mic lookup error: dial tcp 127.0.0.1:6379: connect: connection refused"
Dec 26 17:06:40 chirpstack-application-server[111591]: time="2021-12-26T17:06:40.013568806+01:00" level=info msg="gateway ping created" ctx_id=6e03aac8-e78c-4e44-8777-96e7b2be6a39 dr=60 frequency=60 gateway_mac=a840411dae204150 id=604603
Dec 26 17:06:40 chirpstack-application-server[111591]: time="2021-12-26T17:06:40.128822202+01:00" level=error msg="send gateway ping error: store mic lookup error: set mic lookup error: dial tcp 127.0.0.1:6379: connect: connection refused"
Dec 26 17:06:41 chirpstack-application-server[111591]: time="2021-12-26T17:06:41.13685097+01:00" level=info msg="gateway ping created" ctx_id=01b8c2e1-bf83-4463-96e0-5fa23fc462a9 dr=60 frequency=60 gateway_mac=a840411dae204150 id=604604
Dec 26 17:06:41 chirpstack-application-server[111591]: time="2021-12-26T17:06:41.202311519+01:00" level=error msg="send gateway ping error: store mic lookup error: set mic lookup error: dial tcp 127.0.0.1:6379: connect: connection refused"
Dec 26 17:06:42 chirpstack-application-server[111591]: time="2021-12-26T17:06:42.208250044+01:00" level=info msg="gateway ping created" ctx_id=8096cdea-f575-4a22-9785-67cb82dad8cf dr=60 frequency=60 gateway_mac=a840411dae204150 id=604605
Dec 26 17:06:42 chirpstack-application-server[111591]: time="2021-12-26T17:06:42.311669754+01:00" level=error msg="send gateway ping error: store mic lookup error: set mic lookup error: dial tcp 127.0.0.1:6379: connect: connection refused"
Dec 26 17:06:43 chirpstack-application-server[111591]: time="2021-12-26T17:06:43.314994016+01:00" level=info msg="gateway ping created" ctx_id=331d5573-cd67-471e-8d04-31584aeaae1a dr=60 frequency=60 gateway_mac=a840411dae204150 id=604606
Dec 26 17:06:43 chirpstack-application-server[111591]: time="2021-12-26T17:06:43.401306218+01:00" level=error msg="send gateway ping error: store mic lookup error: set mic lookup error: dial tcp 127.0.0.1:6379: connect: connection refused"
Dec 26 17:06:44 chirpstack-application-server[111591]: time="2021-12-26T17:06:44.404957515+01:00" level=info msg="gateway ping created" ctx_id=503e0dd3-3216-471a-a01f-532fcab1c1ea dr=60 frequency=60 gateway_mac=a840411dae204150 id=604607
Dec 26 17:06:44 chirpstack-application-server[111591]: time="2021-12-26T17:06:44.512356439+01:00" level=error msg="send gateway ping error: store mic lookup error: set mic lookup error: dial tcp 127.0.0.1:6379: connect: connection refused"
Dec 26 17:06:45 chirpstack-application-server[111591]: time="2021-12-26T17:06:45.515588893+01:00" level=info msg="gateway ping created" ctx_id=8fb94b31-209c-4080-9562-b0e64992cde8 dr=60 frequency=60 gateway_mac=a840411dae204150 id=604608
Dec 26 17:06:45 chirpstack-application-server[111591]: time="2021-12-26T17:06:45.60919041+01:00" level=error msg="send gateway ping error: store mic lookup error: set mic lookup error: dial tcp 127.0.0.1:6379: connect: connection refused"
Dec 26 17:06:46 chirpstack-application-server[111591]: time="2021-12-26T17:06:46.613808144+01:00" level=info msg="gateway ping created" ctx_id=9e5894e4-6133-45b3-a494-109cb504c81d dr=60 frequency=60 gateway_mac=a840411dae204150 id=604609
Dec 26 17:06:46 chirpstack-application-server[111591]: time="2021-12-26T17:06:46.734475773+01:00" level=error msg="send gateway ping error: store mic lookup error: set mic lookup error: dial tcp 127.0.0.1:6379: connect: connection refused"
Dec 26 17:06:47 chirpstack-application-server[111591]: time="2021-12-26T17:06:47.739609874+01:00" level=info msg="gateway ping created" ctx_id=b090a36b-8586-422c-8595-a8a5d3a09a6f dr=60 frequency=60 gateway_mac=a840411dae204150 id=604610
Dec 26 17:06:47 chirpstack-application-server[111591]: time="2021-12-26T17:06:47.83636693+01:00" level=error msg="send gateway ping error: store mic lookup error: set mic lookup error: dial tcp 127.0.0.1:6379: connect: connection refused"
Dec 26 17:06:48 chirpstack-application-server[111591]: time="2021-12-26T17:06:48.839999433+01:00" level=info msg="gateway ping created" ctx_id=1aa4eab5-ff0d-4030-8433-7d3be4d39d32 dr=60 frequency=60 gateway_mac=a840411dae204150 id=604611
Dec 26 17:06:48 chirpstack-application-server[111591]: time="2021-12-26T17:06:48.926385603+01:00" level=error msg="send gateway ping error: store mic lookup error: set mic lookup error: dial tcp 127.0.0.1:6379: connect: connection refused"
Dec 26 17:06:49 chirpstack-application-server[111591]: time="2021-12-26T17:06:49.930674496+01:00" level=info msg="gateway ping created" ctx_id=c931e289-c18b-44a9-a465-8e9badf23131 dr=60 frequency=60 gateway_mac=a840411dae204150 id=604612
Dec 26 17:06:50 chirpstack-application-server[111591]: time="2021-12-26T17:06:50.007490795+01:00" level=error msg="send gateway ping error: store mic lookup error: set mic lookup error: dial tcp 127.0.0.1:6379: connect: connection refused"
Dec 26 17:06:51 chirpstack-application-server[111591]: time="2021-12-26T17:06:51.010556282+01:00" level=info msg="gateway ping created" ctx_id=aca1b1c8-e2a7-450b-9e2f-d512676bc843 dr=60 frequency=60 gateway_mac=a840411dae204150 id=604613
Dec 26 17:06:51 chirpstack-application-server[111591]: time="2021-12-26T17:06:51.093839639+01:00" level=error msg="send gateway ping error: store mic lookup error: set mic lookup error: dial tcp 127.0.0.1:6379: connect: connection refused"
Dec 26 17:06:52 chirpstack-application-server[111591]: time="2021-12-26T17:06:52.097536998+01:00" level=info msg="gateway ping created" ctx_id=830aae88-2def-41af-9c95-035bbb1c2df7 dr=60 frequency=60 gateway_mac=a840411dae204150 id=604614
Dec 26 17:06:52 chirpstack-application-server[111591]: time="2021-12-26T17:06:52.195295302+01:00" level=warning msg="[core] grpc: addrConn.createTransport failed to connect to {localhost:8000 localhost:8000 <nil> 0 <nil>}. Err: connection error: desc = \"transport: Error while dialing dial tcp 127.0.0.1:8000: connect: connection refused\". Reconnecting..."
Dec 26 17:06:52 chirpstack-application-server[111591]: time="2021-12-26T17:06:52.209508782+01:00" level=error msg="send gateway ping error: store mic lookup error: set mic lookup error: dial tcp 127.0.0.1:6379: connect: connection refused"
Dec 26 17:06:53 chirpstack-application-server[111591]: time="2021-12-26T17:06:53.213781263+01:00" level=info msg="gateway ping created" ctx_id=e71a25e5-f0cb-4437-bd93-3170921daaa9 dr=60 frequency=60 gateway_mac=a840411dae204150 id=604615
Dec 26 17:06:53 chirpstack-application-server[111591]: time="2021-12-26T17:06:53.294773226+01:00" level=error msg="send gateway ping error: store mic lookup error: set mic lookup error: dial tcp 127.0.0.1:6379: connect: connection refused"
Dec 26 17:06:54 chirpstack-application-server[111591]: time="2021-12-26T17:06:54.299981234+01:00" level=info msg="gateway ping created" ctx_id=9c881855-bd13-4236-9335-fa59321e3dc2 dr=60 frequency=60 gateway_mac=a840411dae204150 id=604616
Dec 26 17:06:54 chirpstack-application-server[111591]: time="2021-12-26T17:06:54.408929745+01:00" level=error msg="send gateway ping error: store mic lookup error: set mic lookup error: dial tcp 127.0.0.1:6379: connect: connection refused"
Dec 26 17:06:55 chirpstack-application-server[111591]: time="2021-12-26T17:06:55.412968052+01:00" level=info msg="gateway ping created" ctx_id=071160af-414a-46c8-9f5b-ee030045a1c4 dr=60 frequency=60 gateway_mac=a840411dae204150 id=604617
Dec 26 17:06:55 chirpstack-application-server[111591]: time="2021-12-26T17:06:55.478289046+01:00" level=error msg="send gateway ping error: store mic lookup error: set mic lookup error: dial tcp 127.0.0.1:6379: connect: connection refused"
Dec 26 17:06:56 chirpstack-application-server[111591]: time="2021-12-26T17:06:56.482455027+01:00" level=info msg="gateway ping created" ctx_id=cf5491ec-c467-4c0f-8cc0-3f8c8df5f279 dr=60 frequency=60 gateway_mac=a840411dae204150 id=604618
Dec 26 17:06:56 chirpstack-application-server[111591]: time="2021-12-26T17:06:56.595889385+01:00" level=error msg="send gateway ping error: store mic lookup error: set mic lookup error: dial tcp 127.0.0.1:6379: connect: connection refused"
Dec 26 17:06:57 chirpstack-application-server[111591]: time="2021-12-26T17:06:57.531210198+01:00" level=info msg="signal received" signal=terminated
Dec 26 17:06:57 systemd[1]: Stopping ChirpStack Application Server...
Dec 26 17:06:57 chirpstack-application-server[111591]: time="2021-12-26T17:06:57.543756591+01:00" level=warning msg="stopping chirpstack-application-server"
Dec 26 17:06:57 systemd[1]: chirpstack-application-server.service: Succeeded.
Dec 26 17:06:57 systemd[1]: Stopped ChirpStack Application Server.
I see that the application server cannot make any connection to the redis server, but that the connection is getting refused. The redis server is running fine.
When ever I look at what is running (docker-compose ps), I can see that the application server is the only one that is not running (please see picture below).
I am trying to run it on ubuntu 20.
What am i doing wrong? Can anybody please help to understand what i need to do differently?
Thanks in advance
Khadar
