Just installed the latest ChripstackOS with an RPI 4:
chirpstack-gateway-os-full-raspberrypi4-20200720152644.rootfs.wic.gz
Everything seems to be running fine, but I cannot log into the User Interface on port 8080. All I get is a page with the 2 links
/swagger/
/vendor/
I can follow these links (and using the api with swagger works great!), but where is the UI?
Thanks your help
John
Here is the log:
root@raspberrypi4:~# chirpstack-application-server
INFO[0000] starting ChirpStack Application Server docs="[removed link]chirpstack.io/" version=3.11.0
INFO[0000] storage: setting up storage package
INFO[0000] storage: setup metrics
INFO[0000] storage: setting up Redis client
INFO[0000] storage: connecting to PostgreSQL database
INFO[0000] storage: applying PostgreSQL data migrations
INFO[0000] storage: PostgreSQL data migrations applied count=0
INFO[0000] integration: configuring global integrations
INFO[0000] integration/mqtt: TLS config is empty
INFO[0000] integration/mqtt: connecting to mqtt broker server=“tcp://localhost:1883”
INFO[0000] integration/mqtt: connected to mqtt broker
INFO[0000] integration/mqtt: subscribing to tx topic qos=0 topic=application/+/device/+/command/down
INFO[0000] api/as: starting application-server api bind=“0.0.0.0:8001” ca_cert= tls_cert= tls_key=
INFO[0000] api/external: starting api server bind=“0.0.0.0:8080” tls-cert= tls-key=
INFO[0000] api/external: registering rest api handler and documentation endpoint path=/api
INFO[0000] api/js: starting join-server api bind=“0.0.0.0:8003” ca_cert= tls_cert= tls_key=
