Please find below my config file…
[general]
# Log level
log_level=4
# Log to syslog.
# When set to true, log messages are being written to syslog.
log_to_syslog=true
# The number of times passwords must be hashed. A higher number is safer as
# an attack takes more time to perform.
password_hash_iterations=100000
# PostgreSQL settings.
# Please note that PostgreSQL 9.5+ is required.
[postgresql]
# PostgreSQL dsn (e.g.: postgres://user:password@hostname/database?sslmode=disable).
# Besides using an URL (e.g. 'postgres://user:password@hostname/database?sslmode=disable')
# it is also possible to use the following format:
# 'user=chirpstack_as dbname=chirpstack_as sslmode=disable'.
# The following connection parameters are supported:
# * dbname - The name of the database to connect to
# * user - The user to sign in as
# * password - The user's password
# * host - The host to connect to. Values that start with / are for unix domain sockets. (default is localhost)
# * port - The port to bind to. (default is 5432)
# * sslmode - Whether or not to use SSL (default is require, this is not the default for libpq)
# * fallback_application_name - An application_name to fall back to if one isn't provided.
# * connect_timeout - Maximum wait for connection, in seconds. Zero or not specified means wait indefinitely.
# * sslcert - Cert file location. The file must contain PEM encoded data.
# * sslkey - Key file location. The file must contain PEM encoded data.
# * sslrootcert - The location of the root certificate file. The file must contain PEM encoded data.
# Valid values for sslmode are:
# * disable - No SSL
dsn="postgres://username:password@localhost/chirpstack_as?sslmode=disable"
# Automatically apply database migrations.
# It is possible to apply the database-migrations by hand
# (see https://github.com/brocaar/chirpstack-application-server/tree/master/migrations)
# or let ChirpStack Application Server migrate to the latest state automatically, by using
# this setting. Make sure that you always make a backup when upgrading Lora
# App Server and / or applying migrations.
automigrate=true
# Max open connections.
# PostgreSQL connection pool (0 = unlimited).
max_open_connections=0
# Max idle connections.
# This sets the max. number of idle connections in the PostgreSQL connection
# pool (0 = no idle connections are retained).
max_idle_connections=2
# Redis settings
# Please note that Redis 2.6.0+ is required.
[redis]
servers=[
"localhost:6379",
# Password.
# Set the password when connecting to Redis requires password authentication.
password=""
# Database index.
# By default, this can be a number between 0-15.
database=0
# Redis Cluster.
# instance.
cluster=false
# Master name.
# Set the master name when the provided URLs are pointing to a Redis Sentinel
# instance.
master_name=""
# Connection pool size.
# Default (when set to 0) is 10 connections per every CPU.
pool_size=0
# Application-server settings.
[application_server]
# Application-server identifier.
# Random UUID defining the id of the application-server installation (used by
# ChirpStack Network Server as routing-profile id).
# For now it is recommended to not change this id.
id="6d5db27e-4ce2-4b2b-b5d7-91f069397978"
# User authentication
[application_server.user_authentication]
# OpenID Connect.
[application_server.user_authentication.openid_connect]
# Enable OpenID Connect authentication.
# Enabling this option replaces password authentication.
enabled=false
# Registration enabled.
# Enabling this will automatically register the user when it is not yet present
# in the ChirpStack Application Server database. There is no
# registration form as the user information is automatically received using the
# OpenID Connect provided information.
# The user will not be associated with any organization, but in order to
# facilitate the automatic onboarding of users, it is possible to configure a
# registration callback URL (next config option).
registration_enabled=false
# Registration callback URL.
# This (optional) endpoint will be called on the registration of the user and
# can implement the association of the user with an organization, create a new
# organization, ...
# ChirpStack Application Server will make a HTTP POST call to this endpoint,
# with the URL parameter user_id.
registration_callback_url=""
# Provider URL.
# This is the URL of the OpenID Connect provider.
provider_url=""
# Client ID.
client_id=""
# Client secret.
client_secret=""
# Redirect URL.
# This must contain the ChirpStack Application Server web-interface hostname
# with '/auth/oidc/callback' path, e.g. https://example.com/auth/oidc/callback.
redirect_url=""
# Logout URL.
# When set, ChirpStack Application Server will redirect to this URL instead
# of redirecting to the login page.
logout_url=""
# Login label.
# The login label is used in the web-interface login form.
login_label=""
# JavaScript codec settings.
[application_server.codec.js]
# Maximum execution time.
max_execution_time="100ms"
# Integration configures the data integration.
# This is the data integration which is available for all applications,
# besides the extra integrations that can be added on a per-application
# basis.
# Payload marshaler.
# This defines how the MQTT payloads are encoded. Valid options are:
# * protobuf: Protobuf encoding
# * json: JSON encoding (easier for debugging, but less compact than 'protobuf')
# * json_v3: v3 JSON (will be removed in the next major release)
marshaler="json_v3"
# Enabled integrations.
# Enabled integrations are enabled for all applications. Multiple
# integrations can be configured.
# Do not forget to configure the related configuration section below for
# the enabled integrations. Integrations that can be enabled are:
# * mqtt - MQTT broker
# * amqp - AMQP / RabbitMQ
# * aws_sns - AWS Simple Notification Service (SNS)
# * azure_service_bus - Azure Service-Bus
# * gcp_pub_sub - Google Cloud Pub/Sub
# * kafka - Kafka distributed streaming platform
# * postgresql - PostgreSQL database
enabled=["mqtt"]
# MQTT integration backend.
# Event topic template.
event_topic_template="application/{{ .ApplicationID }}/device/{{ .DevEUI }}/event/{{ .EventType }}"
# Command topic template.
command_topic_template="application/{{ .ApplicationID }}/device/{{ .DevEUI }}/command/{{ .CommandType }}"
# Retain events.
# The MQTT broker will store the last publised message, when retain events is set
# to true. When a MQTT client connects and subscribes, it will always receive the
# last published message.
retain_events=false
server="tcp://localhost:1883"
username=""
password=""
# Maximum interval that will be waited between reconnection attempts when connection is lost.
# Valid units are 'ms', 's', 'm', 'h'. Note that these values can be combined, e.g. '24h30m15s'.
max_reconnect_interval="1m0s"
# Quality of service level
# 0: at most once
# 1: at least once
# 2: exactly once
qos=0
# Clean session
clean_session=true
# Client ID
client_id=""
ca_cert=""
tls_cert=""
# TLS key file (optional)
tls_key=""
# AMQP / RabbitMQ.
[application_server.integration.amqp]
# Server URL.
# See for a specification of all the possible options:
# https://www.rabbitmq.com/uri-spec.html
url="amqp://guest:guest@localhost:5672"
# Event routing key template.
# This is the event routing-key template used when publishing device
# events.
event_routing_key_template="application.{{ .ApplicationID }}.device.{{ .DevEUI }}.event.{{ .EventType }}"
# AWS Simple Notification Service (SNS)
[application_server.integration.aws_sns]
# AWS region.
# Example: "eu-west-1".
# See also: https://docs.aws.amazon.com/general/latest/gr/rande.html.
aws_region=""
# AWS Access Key ID.
aws_access_key_id=""
# AWS Secret Access Key.
aws_secret_access_key=""
# Topic ARN (SNS).
topic_arn=""
# Azure Service-Bus integration.
[application_server.integration.azure_service_bus]
# Connection string.
# The connection string can be found / created in the Azure console under
# Settings -> Shared access policies. The policy must contain Manage & Send.
connection_string=""
# Publish mode.
# Select either "topic", or "queue".
publish_mode=""
# Publish name.
# The name of the topic or queue.
publish_name=""
# Google Cloud Pub/Sub integration.
[application_server.integration.gcp_pub_sub]
# Path to the IAM service-account credentials file.
# Note: this service-account must have the following Pub/Sub roles:
# * Pub/Sub Editor
credentials_file=""
# Google Cloud project id.
project_id=""
# Pub/Sub topic name.
topic_name=""
# Kafka integration.
[application_server.integration.kafka]
# Brokers, e.g.: localhost:9092.
brokers=["localhost:9092"]
# TLS.
# Set this to true when the Kafka client must connect using TLS to the Broker.
tls=false
# Topic for events.
topic="chirpstack_as"
# Template for keys included in Kafka messages. If empty, no key is included.
# Kafka uses the key for distributing messages over partitions. You can use
# this to ensure some subset of messages end up in the same partition, so
# they can be consumed in-order. And Kafka can use the key for data retention
# decisions. A header "event" with the event type is included in each
# message. There is no need to parse it from the key.
event_key_template="application.{{ .ApplicationID }}.device.{{ .DevEUI }}.event.{{ .EventType }}"
# Username (optional).
username=""
# Password (optional).
password=""
# PostgreSQL database integration.
[application_server.integration.postgresql]
dsn=""
# Settings for the "internal api"
# This is the API used by ChirpStack Network Server to communicate with ChirpStack Application Server
# and should not be exposed to the end-user.
[application_server.api]
bind="0.0.0.0:8001"
# ca certificate used by the api server (optional)
ca_cert=""
# tls certificate used by the api server (optional)
tls_cert=""
# tls key used by the api server (optional)
tls_key=""
# Public ip:port of the application-server API.
# This is used by ChirpStack Network Server to connect to ChirpStack Application Server. When running
# ChirpStack Application Server on a different host than ChirpStack Network Server, make sure to set
# this to the host:ip on which ChirpStack Network Server can reach ChirpStack Application Server.
# The port must be equal to the port configured by the 'bind' flag
# above.
public_host="localhost:8001"
# Settings for the "external api"
# This is the API and web-interface exposed to the end-user.
# ip:port to bind the (user facing) http server to (web-interface and REST / gRPC api)
bind="0.0.0.0:8080"
# http server TLS certificate (optional)
tls_cert=""
# http server TLS key (optional)
tls_key=""
# JWT secret used for api authentication / authorization
# You could generate this by executing 'openssl rand -base64 32' for example
jwt_secret=""
# Allow origin header (CORS).
# Set this to allows cross-domain communication from the browser (CORS).
# Example value: https://example.com.
# When left blank (default), CORS will not be used.
cors_allow_origin=""
# Settings for the remote multicast setup.
[application_server.remote_multicast_setup]
# Synchronization interval.
sync_interval="1s"
# Synchronization retries.
sync_retries=3
# Synchronization batch-size.
sync_batch_size=100
# Settings for the fragmentation-session setup.
[application_server.fragmentation_session]
sync_interval="1s"
sync_retries=3
sync_batch_size=100
# Join-server configuration.
# ChirpStack Application Server implements a (subset) of the join-api specified by the
# LoRaWAN Backend Interfaces specification. This API is used by ChirpStack Network Server
# to handle join-requests.
[join_server]
# ip:port to bind the join-server api interface to
bind="0.0.0.0:8003"
# CA certificate (optional).
# When set, the server requires a client-certificate and will validate this
# certificate on incoming requests.
ca_cert=""
# TLS server-certificate (optional).
# Set this to enable TLS.
tls_cert=""
# TLS server-certificate key (optional).
tls_key=""
# Key Encryption Key (KEK) configuration.
# The KEK mechanism is used to encrypt the session-keys sent from the
# join-server to the network-server.
# The ChirpStack Application Server join-server will use the NetID of the requesting
# network-server as the KEK label. When no such label exists in the set,
# the session-keys will be sent unencrypted (which can be fine for
# private networks).
# Please refer to the LoRaWAN Backend Interface specification
# 'Key Transport Security' section for more information.
[join_server.kek]
# Application-server KEK label.
# This defines the KEK label used to encrypt the AppSKey (note that the
# AppSKey is signaled to the NS and on the first received uplink from the
# NS to the AS).
# When left blank, the AppSKey will be sent unencrypted (which can be fine
# for private networks).
as_kek_label=""
# KEK set.
# Example (the [[join_server.kek.set]] can be repeated):
# [[join_server.kek.set]]
# # KEK label.
# label="000000"
# # Key Encryption Key.
# kek="01020304050607080102030405060708"
# Metrics collection settings.
[metrics]
# Timezone
# The timezone is used for correctly aggregating the metrics (e.g. per hour,
# day or month).
# Example: "Europe/Amsterdam" or "Local" for the the system's local time zone.
timezone="Local"
# Metrics stored in Redis.
# The following metrics are stored in Redis:
# * gateway statistics
[metrics.redis]
# Aggregation intervals
# The intervals on which to aggregate. Available options are:
# 'MINUTE', 'HOUR', 'DAY', 'MONTH'.
aggregation_intervals=["MINUTE", "HOUR", "DAY", "MONTH"]
# Aggregated statistics storage duration.
minute_aggregation_ttl="2h0m0s"
hour_aggregation_ttl="48h0m0s"
day_aggregation_ttl="2160h0m0s"
month_aggregation_ttl="17520h0m0s"
# Metrics stored in Prometheus.
# These metrics expose information about the state of the ChirpStack Network Server
# instance.
[metrics.prometheus]
# Enable Prometheus metrics endpoint.
endpoint_enabled=false
# The ip:port to bind the Prometheus metrics server to for serving the
# metrics endpoint.
bind=""
# API timing histogram.
# By setting this to true, the API request timing histogram will be enabled.
# See also: https://github.com/grpc-ecosystem/go-grpc-prometheus#histograms
api_timing_histogram=false
# Monitoring settings.
# Note that this replaces the metrics.prometheus configuration. If a
# metrics.prometheus if found in the configuration then it will fall back
# to that and the monitoring section is ignored.
[monitoring]
# IP:port to bind the monitoring endpoint to.
# When left blank, the monitoring endpoint will be disabled.
bind=""
# Prometheus metrics endpoint.
# When set to true, Prometheus metrics will be served at '/metrics'.
prometheus_endpoint=false
# Prometheus API timing histogram.
prometheus_api_timing_histogram=false
# Health check endpoint.
# When set to true, the healthcheck endpoint will be served at '/health'.
# When requesting, this endpoint will perform the following actions to
# determine the health of this service:
# * Ping PostgreSQL database
# * Ping Redis database
healthcheck_endpoint=false
