I am trying to connect multi tech conduit to chirpstack gatway bridge. The following is the bridge configuration
[backend.basic_station]
# Region.
# Please refer to the LoRaWAN Regional Parameters specification
# for the complete list of common region names.
region="US915"
# Minimal frequency (Hz).
frequency_min=902000000
# Maximum frequency (Hz).
frequency_max=928000000
# Concentrator configuration.
# This section contains the configuration for the SX1301 concentrator chips.
# Example:
[[backend.basic_station.concentrators]]
# Multi-SF channel configuration.
[backend.basic_station.concentrators.multi_sf]
#Frequencies (Hz).
frequencies=[
903900000,
904100000,
904300000,
904500000,
904700000,
904900000,
905100000,
905300000,
# LoRa STD channel.
#[backend.basic_station.concentrators.lora_std]
# Frequency (Hz).
#frequency=868300000
#frequency=904600000
# Bandwidth (Hz).
#bandwidth=250000
#bandwidth=500000
# Spreading factor.
#spreading_factor=8
# FSK channel.
#[backend.basic_station.concentrators.fsk]
# Frequency (Hz).
#frequency=868800000
I am unable to recceive any uplinks from the end device…Below is the basic station log from the multitech device.
root@mtcdt:/var/run/lora/1# ./station
2021-01-24 18:05:02.346 [SYS:INFO] Logging : stderr (maxsize=100000, rotate=3)
2021-01-24 18:05:02.347 [SYS:INFO] Station Ver : 2.0.5(mlinux/std) 2020-10-19 19:44:13
2021-01-24 18:05:02.348 [SYS:INFO] Package Ver : (null)
2021-01-24 18:05:02.350 [SYS:INFO] proto EUI : 80:0:a000:474d (station.conf)
2021-01-24 18:05:02.352 [SYS:INFO] prefix EUI : ::0 (station.conf)
2021-01-24 18:05:02.352 [SYS:INFO] Station EUI : 80:0:a000:474d
2021-01-24 18:05:02.353 [SYS:INFO] Station home: ./ (builtin)
2021-01-24 18:05:02.353 [SYS:INFO] Station temp: /var/tmp/ (builtin)
2021-01-24 18:05:02.353 [SYS:WARN] Station in NO-CUPS mode
2021-01-24 18:05:02.556 [TCE:INFO] Starting TC engine
2021-01-24 18:05:02.571 [TCE:INFO] Connecting to INFOS: ws://192.168.1.8:3001
2021-01-24 18:05:02.580 [TCE:INFO] Infos: 0080:0000:a000:474d 0080:0000:a000:474d
ws://192.168.1.8:3001/gateway/00800000a000474d
2021-01-24 18:05:02.592 [RAL:INFO] Lora gateway library version: Version: 5.0.1-mts-5;
INFO: FPGA supported features: [TX filter] [Spectral Scan]
2021-01-24 18:05:05.808 [S2E:INFO] Configuring for region: US902 -- 902.0MHz..928.0MHz
2021-01-24 18:05:47.882 [SYN:INFO] MCU/SX130X drift stats: min: -12.8ppm q50: -17.1ppm q80:
-19.0ppm max: -78.5ppm - threshold q90: +40.0ppm
2021-01-24 18:05:47.882 [SYN:INFO] Mean MCU drift vs SX130X#0: -16.9ppm
After [TX filter] [Spectral Scan] am supposed to data rate log as per this Running Basic Station on Conduit . Can someone tell me What other configuration needs to be set?
