Hi everyone,
I’m actually struggling, probably on a little step i missed.
I’m willing to upgrade my LoRaServer to ChirpStack, in my Docker installation, without losing the data of my LoRa devices.
Following @brocaar’s announcement (by the way, you’re amazing! thanks a lot for your work), and some other topics found in the community’s forum, I updated both docker-compose.yml and docker-compose-env.yml files with the new names of the images:
loraserver\loraserver
-->chirpstack\chirpstack-network-server
- volume:
./configuration/loraserver
-->./configuration/chirpstack-network-server
- directory:
loraserver
-->chirpstack-network-server
And so on, renaming also the other components and directories.
I stopped the containers loraserver, lora-gateway-bridge, lora-geo-server and lora-application-server, and then i ran the compose.
The bad thing is that when i build the stack with the new images with docker-compose up
, looks like the application server and the network server can’t connect to PostgreSQL, even if i didnt change the name of the services in the files and the credentials of the components (i left loraserver_ns
and loraserver_as
for PostgreSQL in docker-compose-env.yml
file), getting the error “connection refused” for PostgreSQL.
Edit: i can’t even reach the application server on my browser, after running the stack…
What am I missing?
Thank you for any kind of help!
