I am stuck in a paradox situation, I can’t find, add, edit, or even delete a group of devices
The search using the DevEUI show up no results:
Adding this same devEUI give this error message: “object already exists (code: 6)”
Using the /api/ to detele the same device, I’ve got the same error:
If I try to EDIT using put /api/devices/{device.dev_eui} ( [Update updates the device matching the given DevEUI.])
→ it return: Device or Object does not exist.
It looks that this nodes was there, and maybe badly inserted in the Chirpstack database ?
if it’s the case , how I can delete it ?
Any suggestion please ?
Many Thanks
Tao
