Hello every one
Follow the “Quick Install” guide, I had installed it both in a virtural machine and in a AWS server.
The one in the virtural machine works well, and I can open the website via https://localhost:8080
But if I can’t open my AWS lorawan server with https://47.104 .***.32:8080 (47.104.***.32 is my AWS server’s IP address).
I think there must need some special config, how can I solve that problem?
Hope someone can give me
brocaar
January 10, 2018, 3:43pm
#2
Please check the logs to make sure LoRa (App) Server is started
Check your firewall rules
Please also share what you already tried to debug this issue
Thanks for you reply Brocaar
Both LoRa Server and LoRa App Server are running, I had checked with follow commands:
sudo systemctl status lora-app-server
sudo systemctl status loraserver
Should I open 8080, 1700, 1883, 1884 ports by hand?
I sloved this problem…Just add allow to 8080 port with TCP protocol is enough:rofl:
