Here’s the log file, it says I can’t add the rest as I can only add 2 links.
raspberrypi3:~$ sudo tail -f /var/log/messages | grep chirpstack-concentratord
Aug 01 16:33:25 raspberrypi3 user.info chirpstack-concentratord-sx1301[741]: Configuring multi-SF LoRa channel, channel: 5, enabled: true, freq: 867500000, rf_chain: 0, if_freq: 0
Aug 01 16:33:25 raspberrypi3 user.info chirpstack-concentratord-sx1301[741]: Configuring multi-SF LoRa channel, channel: 6, enabled: true, freq: 867700000, rf_chain: 0, if_freq: 200000
Aug 01 16:33:25 raspberrypi3 user.info chirpstack-concentratord-sx1301[741]: Configuring multi-SF LoRa channel, channel: 7, enabled: true, freq: 867900000, rf_chain: 0, if_freq: 400000
Aug 01 16:33:25 raspberrypi3 user.info chirpstack-concentratord-sx1301[741]: Configuring Std LoRa channel, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000
Aug 01 16:33:25 raspberrypi3 user.info chirpstack-concentratord-sx1301[741]: Configuring FSK channel, enabled: true, freq: 868800000, rf_chain: 1, if_freq: 300000
Aug 01 16:33:25 raspberrypi3 user.info chirpstack-concentratord-sx1301[741]: Starting the concentrator
Aug 1 16:33:35 raspberrypi3 user.err monit[471]: ‘chirpstack-concentratord’ process is not running
Aug 1 16:33:35 raspberrypi3 user.info monit[471]: ‘chirpstack-concentratord’ trying to restart
Aug 1 16:33:35 raspberrypi3 user.info monit[471]: ‘chirpstack-concentratord’ start: ‘/etc/init.d/chirpstack-concentratord start’
Aug 01 16:33:35 raspberrypi3 user.info chirpstack-concentratord-sx1301[748]: Configuring reset pin, pin: 17
Aug 01 16:33:35 raspberrypi3 user.info chirpstack-concentratord-sx1301[748]: Starting Concentratord SX1301 (version: 3.0.0-test.10, docs: https://www.chirpstack.io/concentratord/)
Aug 01 16:33:35 raspberrypi3 user.info chirpstack-concentratord-sx1301[748]: Triggering concentrator reset
Aug 01 16:33:36 raspberrypi3 user.info chirpstack-concentratord-sx1301[748]: Setting spi device path, spidev_path: /dev/spidev0.0
Aug 01 16:33:36 raspberrypi3 user.info chirpstack-concentratord-sx1301[748]: Setting board configuration, lorawan_public: true, clock_source: 1
Aug 01 16:33:36 raspberrypi3 user.info chirpstack-concentratord-sx1301[748]: Setting up concentrator radios
Aug 01 16:33:36 raspberrypi3 user.info chirpstack-concentratord-sx1301[748]: Configuring radio, radio: 0, enabled: true, center_freq: 867500000, type: SX1257
Aug 01 16:33:36 raspberrypi3 user.info chirpstack-concentratord-sx1301[748]: Configuring radio, radio: 1, enabled: true, center_freq: 868500000, type: SX1257
Aug 01 16:33:36 raspberrypi3 user.info chirpstack-concentratord-sx1301[748]: Setting up concentrator channels
Aug 01 16:33:36 raspberrypi3 user.info chirpstack-concentratord-sx1301[748]: Configuring multi-SF LoRa channel, channel: 0, enabled: true, freq: 868100000, rf_chain: 1, if_freq: -400000
Aug 01 16:33:36 raspberrypi3 user.info chirpstack-concentratord-sx1301[748]: Configuring multi-SF LoRa channel, channel: 1, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000
Aug 01 16:33:36 raspberrypi3 user.info chirpstack-concentratord-sx1301[748]: Configuring multi-SF LoRa channel, channel: 2, enabled: true, freq: 868500000, rf_chain: 1, if_freq: 0
Aug 01 16:33:36 raspberrypi3 user.info chirpstack-concentratord-sx1301[748]: Configuring multi-SF LoRa channel, channel: 3, enabled: true, freq: 867100000, rf_chain: 0, if_freq: -400000
Aug 01 16:33:36 raspberrypi3 user.info chirpstack-concentratord-sx1301[748]: Configuring multi-SF LoRa channel, channel: 4, enabled: true, freq: 867300000, rf_chain: 0, if_freq: -200000
Aug 01 16:33:36 raspberrypi3 user.info chirpstack-concentratord-sx1301[748]: Configuring multi-SF LoRa channel, channel: 5, enabled: true, freq: 867500000, rf_chain: 0, if_freq: 0
Aug 01 16:33:36 raspberrypi3 user.info chirpstack-concentratord-sx1301[748]: Configuring multi-SF LoRa channel, channel: 6, enabled: true, freq: 867700000, rf_chain: 0, if_freq: 200000
Aug 01 16:33:36 raspberrypi3 user.info chirpstack-concentratord-sx1301[748]: Configuring multi-SF LoRa channel, channel: 7, enabled: true, freq: 867900000, rf_chain: 0, if_freq: 400000
Aug 01 16:33:36 raspberrypi3 user.info chirpstack-concentratord-sx1301[748]: Configuring Std LoRa channel, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000
Aug 01 16:33:36 raspberrypi3 user.info chirpstack-concentratord-sx1301[748]: Configuring FSK channel, enabled: true, freq: 868800000, rf_chain: 1, if_freq: 300000
