Chirpstack does not see the RAK7240 gateway
My RAK7340 antenna, which I successfully receive data in V3, does not send data at all in V4 version. Also, Gateway’s Region information is blank on the gateway screen. I don’t know where I did wrong. I’m leaving the chirpstack config settings here just in case
# Logging.
[logging]
  # Log level.
  level="info"
# PostgreSQL configuration.
[postgresql]
  # PostgreSQL DSN.
  # SSL mode options:
  #  * disable - no SSL
  #  * require - Always SSL (skip verification)
  #  * verify-ca - Always SSL (verify that the certificate presented by the server was signed by a trusted CA)
  #  * verify-full - Always SSL (verify that the certification presented by the server was signed by a trusted CA and the server host name matches the one in the certificate)
  dsn="postgres://chirpstack:chirpstack@localhost/chirpstack?sslmode=disable"
  # Max open connections.
  # PostgreSQL connection pool.
  max_open_connections=10
  # Min idle connections.
  min_idle_connections=0
# Redis configuration.
[redis]
  servers=[
    "redis://localhost/",
  # TLS enabled.
  tls_enabled=false
  # Redis Cluster.
  # instance.
  cluster=false
[network]
  net_id="000000"
  # Enabled regions.
  enabled_regions=[
    "as923",
    "as923_2",
    "as923_3",
    "as923_4",
    "au915_0",
    "cn470_10",
    "cn779",
    "eu433",
    "eu868",
    "in865",
    "ism2400",
    "kr920",
    "ru864",
    "us915_0",
    "us915_1",
[api]
  bind="0.0.0.0:8080"
  # Secret.
  #   openssl rand -base64 32
  secret="jihEiFqQ+XZ6IT0lhon0nryRa+XM/fSI8EfSS38MPB8="
[integration]
  enabled=["mqtt"]
  [integration.mqtt]
    server="tcp://localhost:1883/"
    json=true
  • Have you confirmed that the ChirpStack Gateway Bridge / ChirpStack MQTT Forwarder is receiving data from your gateway?
  • Have you confirmed if the GW Bridge / MQTT Forwarder is publishing its stats and uplinks to MQTT?
If the above is all looking good, have you confirmed that the MQTT topics do match the MQTT topics as configured in the region_XXX.toml? E.g. the example config expects eu868/gateway/.... for EU868 etc… Note that v4 added a region prefix (in de default config).
See also v3 to v4 migration - ChirpStack open-source LoRaWAN® Network Server documentation
