I just tried new ChirpStack. The Gateway Bridge can’t receive from the Gateway:
guirong@LoRaSBD:~$ netstat -tulnp
tcp 0 0 127.0.0.1:5432 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN -
tcp 0 0 127.0.0.1:6379 0.0.0.0:* LISTEN -
tcp6 0 0 :::8080 :::* LISTEN -
tcp6 0 0 :::1883 :::* LISTEN -
tcp6 0 0 :::8000 :::* LISTEN -
tcp6 0 0 :::8001 :::* LISTEN -
tcp6 0 0 :::8003 :::* LISTEN -
tcp6 0 0 ::1:6379 :::* LISTEN -
udp6 0 0 :::1700 :::* -
It doesn’t listen listen IPv4 UDP port 1700. The state of IPv6 UDP port 1700 is not LISTEN.
The Postgre is on IPv4, Redis and MQTT are on both IPv4 and IPv6.
Those port on NetworkServer and AppServer are all on IPv6.
Is it the general guidance that IPv6 will be used to replace IPv4 on ChirpStack?
/// Guirong
