chirpstack-network-server
does nothing. Here is the log:
Apr 15 10:12:36 chirp systemd[1]: Stopping ChirpStack Network Server...
Apr 15 10:12:36 chirp systemd[1]: chirpstack-network-server.service: Succeeded.
Apr 15 10:12:36 chirp systemd[1]: Stopped ChirpStack Network Server.
Apr 15 10:12:38 chirp systemd[1]: Started ChirpStack Network Server.
Apr 15 10:12:39 chirp chirpstack-network-server[19752]: time="2022-04-15T10:12:39.041028535Z" level=info msg="starting ChirpStack Network Server" band=EU868 docs="https://www.chirpstack.io/" net_id=000000 version=3.16.1
Apr 15 10:12:39 chirp chirpstack-network-server[19752]: time="2022-04-15T10:12:39.041161955Z" level=info msg="storage: setting up storage module"
Apr 15 10:12:39 chirp chirpstack-network-server[19752]: time="2022-04-15T10:12:39.041177313Z" level=info msg="storage: setting up Redis client"
Apr 15 10:12:39 chirp chirpstack-network-server[19752]: time="2022-04-15T10:12:39.041224682Z" level=info msg="storage: connecting to PostgreSQL"
Apr 15 10:12:39 chirp chirpstack-network-server[19752]: time="2022-04-15T10:12:39.047737674Z" level=info msg="storage: applying PostgreSQL data migrations"
Apr 15 10:12:39 chirp chirpstack-network-server[19752]: time="2022-04-15T10:12:39.050344274Z" level=info msg="gateway/mqtt: connecting to mqtt broker" server="tcp://localhost:1883"
Apr 15 10:12:39 chirp chirpstack-network-server[19752]: time="2022-04-15T10:12:39.050955849Z" level=info msg="api: starting network-server api server" bind="127.0.0.1:8000" ca-cert= tls-cert= tls-key=
Apr 15 10:12:39 chirp chirpstack-network-server[19752]: time="2022-04-15T10:12:39.051109506Z" level=info msg="backend/gateway: connected to mqtt server"
Apr 15 10:12:39 chirp chirpstack-network-server[19752]: time="2022-04-15T10:12:39.051167505Z" level=info msg="gateway/mqtt: subscribing to gateway event topic" qos=0 topic=gateway/+/event/+
Apr 15 10:12:39 chirp chirpstack-network-server[19752]: time="2022-04-15T10:12:39.051241252Z" level=info msg="starting downlink device-queue scheduler"
Apr 15 10:12:39 chirp chirpstack-network-server[19752]: time="2022-04-15T10:12:39.051260038Z" level=info msg="starting multicast scheduler"
Here is the log from chirpstack-gateway-bridge
Apr 15 10:29:31 chirp chirpstack-gateway-bridge[18678]: time="2022-04-15T10:29:31.067872981Z" level=debug msg="[pinger] ping check 30.000301709" module=mqtt
Apr 15 10:29:31 chirp chirpstack-gateway-bridge[18678]: time="2022-04-15T10:29:31.067983398Z" level=debug msg="[pinger] keepalive sending ping" module=mqtt
Apr 15 10:29:31 chirp chirpstack-gateway-bridge[18678]: time="2022-04-15T10:29:31.068391092Z" level=debug msg="[net] startIncoming Received Message" module=mqtt
Apr 15 10:29:31 chirp chirpstack-gateway-bridge[18678]: time="2022-04-15T10:29:31.068420927Z" level=debug msg="[net] startIncomingComms: got msg on ibound" module=mqtt
Apr 15 10:29:31 chirp chirpstack-gateway-bridge[18678]: time="2022-04-15T10:29:31.068434573Z" level=debug msg="[net] startIncomingComms: received pingresp" module=mqtt
Apr 15 10:29:31 chirp chirpstack-gateway-bridge[18678]: time="2022-04-15T10:29:31.068444872Z" level=debug msg="[net] logic waiting for msg on ibound" module=mqtt
Apr 15 10:29:31 chirp chirpstack-gateway-bridge[18678]: time="2022-04-15T10:29:31.3575621Z" level=debug msg="backend/semtechudp: received udp packet from gateway" addr="127.0.0.1:36807" protocol_version=2 type=PullData
Apr 15 10:29:31 chirp chirpstack-gateway-bridge[18678]: time="2022-04-15T10:29:31.357772073Z" level=debug msg="backend/semtechudp: sending udp packet to gateway" addr="127.0.0.1:36807" protocol_version=2 type=PullACK
Apr 15 10:29:31 chirp chirpstack-gateway-bridge[18678]: time="2022-04-15T10:29:31.357849699Z" level=debug msg="integration/mqtt: set gateway subscription" gateway_id=0282ecceb5c160ea subscribe=true
Apr 15 10:29:32 chirp chirpstack-gateway-bridge[18678]: time="2022-04-15T10:29:32.357733224Z" level=debug msg="backend/semtechudp: received udp packet from gateway" addr="127.0.0.1:36807" protocol_version=2 type=PullData
Apr 15 10:29:32 chirp chirpstack-gateway-bridge[18678]: time="2022-04-15T10:29:32.357866894Z" level=debug msg="backend/semtechudp: sending udp packet to gateway" addr="127.0.0.1:36807" protocol_version=2 type=PullACK
Apr 15 10:29:32 chirp chirpstack-gateway-bridge[18678]: time="2022-04-15T10:29:32.357993281Z" level=debug msg="integration/mqtt: set gateway subscription" gateway_id=0282ecceb5c160ea subscribe=true
Apr 15 10:29:33 chirp chirpstack-gateway-bridge[18678]: time="2022-04-15T10:29:33.357433004Z" level=debug msg="backend/semtechudp: received udp packet from gateway" addr="127.0.0.1:36807" protocol_version=2 type=PullData
Apr 15 10:29:33 chirp chirpstack-gateway-bridge[18678]: time="2022-04-15T10:29:33.357535645Z" level=debug msg="backend/semtechudp: sending udp packet to gateway" addr="127.0.0.1:36807" protocol_version=2 type=PullACK
Apr 15 10:29:33 chirp chirpstack-gateway-bridge[18678]: time="2022-04-15T10:29:33.357627517Z" level=debug msg="integration/mqtt: set gateway subscription" gateway_id=0282ecceb5c160ea subscribe=true
So what’s a problem?
