Hello!
I am running V4 - Docker on opensuse 15.4. Everything runs smoothly except one (important) thing. I can’t figure out why Chirpstack drops uplinks from devices occasionally. The logged error looks as follows:
chirpstack-gateway-bridge-eu868_1 | time="2022-11-28T06:37:28.365593599Z" level=info msg="integration/mqtt: publishing event" event=up qos=0 topic=eu868/gateway/b827ebfffe0a8083/event/up uplink_id=43897
chirpstack_1 | 2022-11-28T06:37:28.421438Z INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_name="eu868" topic="eu868/gateway/b827ebfffe0a8083/event/up" qos=0 json=false
chirpstack_1 | 2022-11-28T06:37:28.625379Z INFO up{deduplication_id=86fbf797-5cc8-4ffa-9dcc-89d4fb12742a}: chirpstack::uplink: Uplink received m_type="UnconfirmedDataUp"
chirpstack_1 | 2022-11-28T06:37:28.630961Z INFO up{deduplication_id=86fbf797-5cc8-4ffa-9dcc-89d4fb12742a}:data_up: chirpstack::storage::device_session: Device-session saved dev_eui=4ab1df35680f3a3f dev_addr=260bd5b0
chirpstack_1 | 2022-11-28T06:37:28.632389Z ERROR up{deduplication_id=86fbf797-5cc8-4ffa-9dcc-89d4fb12742a}: chirpstack::uplink::data: Handle uplink error error=Object does not exist (id: 4ab1df35680f3a3f)
I have the same error on both RAK WIsGate Developer gateway and several 1-channel test gateways (EU868 and EU433). The uplink is visible in gateway logs on Chirpstack and on gateways, but error is reported in Chirpstack log.
