bastian
December 8, 2022, 7:09pm
#1
Hello everyone,
I have the following problem: My devices are connected correctly and I get messages in MQTT but the chirp stack does not show any event logging or Lora frames. So far I haven’t found anything in the forum about this, except that redis should work persistently. I changed “appendonly=yes” in redis .conf but it still doesn’t work.
Any ideas?
thank you in advance
updated:
the frame logging only works if I stop the chirpstack…then the frames and events are displayed in the browser. After restarting it doesn’t work anymore. I have no idea?
brocaar
December 9, 2022, 12:13pm
#2
Are you using a proxy in front of ChirpStack, e.g. NGINX? If so, you must add grpc specific config, example:
bastian
December 9, 2022, 4:15pm
#3
hello brocaar,
Thanks for your help!
No, a proxy is not working for me.
I have now only registered 1 gateway and removed every other device. Unfortunately, no frame is displayed, but the message is sent in Mqtt.
Maybe another idea?
Thanks
brocaar
December 9, 2022, 4:53pm
#4
I was not suggesting to use a proxy, just in case you were using one to make sure it is configured to proxy grpc requests
If the messages are published to MQTT but not received by ChirpStack, please make sure that the prefix e.g. eu868/gateway/....
is configured properly.
Also the logs could provide helpful insights
bastian
December 9, 2022, 5:08pm
#5
sorry i expressed myself wrong. I only checked whether a proxy is running. Of course I used the prefix…I’ll read your documentation several times
What logs would be helpful?
brocaar
December 22, 2022, 3:33pm
#6
The log-output from the ChirpStack process. How you could retrieve these depends on how you have installed ChirpStack. E.g. these logs could be captured by Docker, Docker Compose or Systemd. In the latter case you could for example use journalctl -f -n 100 -u chirpstack
bastian
December 23, 2022, 2:04pm
#7
hello brocaar,
here the journalctl. Just over 100 lines. In the meantime I have installed Node-Red and can at least observe the broker messages here. I also installed the Chirpstack on a Raspberry 4 and didn’t change anything in the installation except configured the backend of the gateway bridge to “Semtech_udp”.
I also noticed that the Redis cannot use port 6379. If I configure the port to a high range, the Redis server works. This applies to both installations!
Thanks for the help!
BlockquoteDez 23 13:50:06 iotubuntu chirpstack[812]: 2022-12-23T13:50:06.782073Z DEBUG gRPC{uri=/api.TenantService/Get}: chirpstack::api: Started processing request
Dez 23 13:50:06 iotubuntu chirpstack[812]: 2022-12-23T13:50:06.783231Z INFO gRPC{uri=/api.TenantService/Get}: chirpstack::api: Finished processing request status=“200” latency=1.163541ms
Dez 23 13:50:06 iotubuntu chirpstack[812]: 2022-12-23T13:50:06.810136Z DEBUG gRPC{uri=/api.InternalService/GetDevicesSummary}: chirpstack::api: Started processing request
Dez 23 13:50:06 iotubuntu chirpstack[812]: 2022-12-23T13:50:06.813215Z INFO gRPC{uri=/api.InternalService/GetDevicesSummary}: chirpstack::api: Finished processing request status=“200” latency=3.087442ms
Dez 23 13:50:06 iotubuntu chirpstack[812]: 2022-12-23T13:50:06.813846Z DEBUG gRPC{uri=/api.InternalService/GetGatewaysSummary}: chirpstack::api: Started processing request
Dez 23 13:50:06 iotubuntu chirpstack[812]: 2022-12-23T13:50:06.815016Z DEBUG gRPC{uri=/api.GatewayService/List}: chirpstack::api: Started processing request
Dez 23 13:50:06 iotubuntu chirpstack[812]: 2022-12-23T13:50:06.815651Z INFO gRPC{uri=/api.InternalService/GetGatewaysSummary}: chirpstack::api: Finished processing request status=“200” latency=1.814023ms
Dez 23 13:50:06 iotubuntu chirpstack[812]: 2022-12-23T13:50:06.817150Z INFO gRPC{uri=/api.GatewayService/List}: chirpstack::api: Finished processing request status=“200” latency=2.138091ms
Dez 23 13:50:06 iotubuntu chirpstack[812]: 2022-12-23T13:50:06.837414Z DEBUG http{method=“GET” uri=/logo.png version=HTTP/1.1}: chirpstack::api: Started processing request
Dez 23 13:50:06 iotubuntu chirpstack[812]: 2022-12-23T13:50:06.837717Z INFO http{method=“GET” uri=/logo.png version=HTTP/1.1}: chirpstack::api: Finished processing request status=“200” latency=315.415µs
Dez 23 13:50:06 iotubuntu chirpstack[812]: 2022-12-23T13:50:06.935771Z DEBUG http{method=“GET” uri=/static/media/markers-soft.e52214306ad12a5c837e.png version=HTTP/1.1}: chirpstack::api: Started processing request
Dez 23 13:50:06 iotubuntu chirpstack[812]: 2022-12-23T13:50:06.939297Z INFO http{method=“GET” uri=/static/media/markers-soft.e52214306ad12a5c837e.png version=HTTP/1.1}: chirpstack::api: Finished processing request status=“200” latency=3.574585ms
Dez 23 13:50:06 iotubuntu chirpstack[812]: 2022-12-23T13:50:06.958166Z DEBUG http{method=“GET” uri=/static/media/fa-solid-900.59edf72a325ac2048d60.woff2 version=HTTP/1.1}: chirpstack::api: Started processing request
Dez 23 13:50:06 iotubuntu chirpstack[812]: 2022-12-23T13:50:06.960721Z INFO http{method=“GET” uri=/static/media/fa-solid-900.59edf72a325ac2048d60.woff2 version=HTTP/1.1}: chirpstack::api: Finished processing request status=“200” latency=2.571673ms
Dez 23 13:50:10 iotubuntu chirpstack[812]: 2022-12-23T13:50:10.508387Z DEBUG gRPC{uri=/api.GatewayService/List}: chirpstack::api: Started processing request
Dez 23 13:50:10 iotubuntu chirpstack[812]: 2022-12-23T13:50:10.509832Z INFO gRPC{uri=/api.GatewayService/List}: chirpstack::api: Finished processing request status=“200” latency=1.453395ms
Dez 23 13:50:12 iotubuntu chirpstack[812]: 2022-12-23T13:50:12.708275Z DEBUG gRPC{uri=/api.GatewayService/Get}: chirpstack::api: Started processing request
Dez 23 13:50:12 iotubuntu chirpstack[812]: 2022-12-23T13:50:12.709885Z INFO gRPC{uri=/api.GatewayService/Get}: chirpstack::api: Finished processing request status=“200” latency=1.618452ms
Dez 23 13:50:12 iotubuntu chirpstack[812]: 2022-12-23T13:50:12.771964Z DEBUG gRPC{uri=/api.GatewayService/GetMetrics}: chirpstack::api: Started processing request
Dez 23 13:50:12 iotubuntu chirpstack[812]: 2022-12-23T13:50:12.774455Z INFO gRPC{uri=/api.GatewayService/GetMetrics}: chirpstack::api: Finished processing request status=“200” latency=2.500212ms
Dez 23 13:50:13 iotubuntu chirpstack[812]: 2022-12-23T13:50:13.694738Z DEBUG gRPC{uri=/api.GatewayService/Get}: chirpstack::api: Started processing request
Dez 23 13:50:13 iotubuntu chirpstack[812]: 2022-12-23T13:50:13.696273Z INFO gRPC{uri=/api.GatewayService/Get}: chirpstack::api: Finished processing request status=“200” latency=1.560192ms
Dez 23 13:50:13 iotubuntu chirpstack[812]: 2022-12-23T13:50:13.750001Z DEBUG gRPC{uri=/api.InternalService/StreamGatewayFrames}: chirpstack::api: Started processing request
Dez 23 13:50:13 iotubuntu chirpstack[812]: 2022-12-23T13:50:13.751339Z INFO gRPC{uri=/api.InternalService/StreamGatewayFrames}: chirpstack::api: Finished processing request status=“200” latency=1.356787ms
Dez 23 13:50:16 iotubuntu chirpstack[812]: 2022-12-23T13:50:16.499915Z INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_name=“eu868” topic=“eu868/gateway/a840411fb1804150/event/up” qos=0 json=true
Dez 23 13:50:16 iotubuntu chirpstack[812]: 2022-12-23T13:50:16.701829Z INFO up{deduplication_id=d4eb4e63-5fa3-4f1a-b07c-e89b296deb93}: chirpstack::uplink: Uplink received m_type=“UnconfirmedDataUp”
Dez 23 13:50:16 iotubuntu chirpstack[812]: 2022-12-23T13:50:16.702113Z DEBUG up{deduplication_id=d4eb4e63-5fa3-4f1a-b07c-e89b296deb93}: chirpstack::uplink: Updating gateway meta-data for uplink frame-set
Dez 23 13:50:16 iotubuntu chirpstack[812]: 2022-12-23T13:50:16.702813Z DEBUG up{deduplication_id=d4eb4e63-5fa3-4f1a-b07c-e89b296deb93}: chirpstack::uplink: Logging uplink frame to Redis Stream
Dez 23 13:50:16 iotubuntu chirpstack[812]: 2022-12-23T13:50:16.703649Z INFO up{deduplication_id=d4eb4e63-5fa3-4f1a-b07c-e89b296deb93}:data_up: chirpstack::storage::device_session: Device-session saved dev_eui=24e124136c278697 dev_addr=010d88f9
Dez 23 13:50:16 iotubuntu chirpstack[812]: 2022-12-23T13:50:16.705148Z INFO chirpstack::storage::device: Setting device lock dev_eui=24e124136c278697
Dez 23 13:50:16 iotubuntu chirpstack[812]: 2022-12-23T13:50:16.706311Z INFO up{deduplication_id=d4eb4e63-5fa3-4f1a-b07c-e89b296deb93}:data_up: chirpstack::storage::device: Data-rate updated dev_eui=24e124136c278697 dr=5
Dez 23 13:50:16 iotubuntu chirpstack[812]: 2022-12-23T13:50:16.706745Z INFO up{deduplication_id=d4eb4e63-5fa3-4f1a-b07c-e89b296deb93}:data_up: chirpstack::storage::mac_command: Pending mac-command block deleted dev_eui=24e124136c278697 cid=LinkADRAns
Dez 23 13:50:16 iotubuntu chirpstack[812]: 2022-12-23T13:50:16.706839Z INFO up{deduplication_id=d4eb4e63-5fa3-4f1a-b07c-e89b296deb93}:data_up: chirpstack::maccommand::link_adr: LinkADRReq acknowledged dev_eui=24e124136c278697 tx_power_index=7 dr=5 nb_trans=1 enabled_channels=[0, 1, 2, 3, 4, 5, 6, 7]
Dez 23 13:50:16 iotubuntu chirpstack[812]: 2022-12-23T13:50:16.707039Z INFO up{deduplication_id=d4eb4e63-5fa3-4f1a-b07c-e89b296deb93}:data_up: chirpstack::storage::device_gateway: Gateway rx-info saved dev_eui=24e124136c278697
Dez 23 13:50:16 iotubuntu chirpstack[812]: 2022-12-23T13:50:16.713552Z INFO up{deduplication_id=d4eb4e63-5fa3-4f1a-b07c-e89b296deb93}:data_up: chirpstack::integration::mqtt: Publishing event topic=application/2dd5a192-ce47-4715-9d79-ae413dc1af91/device/24e124136c278697/event/up
Dez 23 13:50:16 iotubuntu chirpstack[812]: 2022-12-23T13:50:16.716309Z INFO up{deduplication_id=d4eb4e63-5fa3-4f1a-b07c-e89b296deb93}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697:temperature aggregation=HOUR
Dez 23 13:50:16 iotubuntu chirpstack[812]: 2022-12-23T13:50:16.716668Z INFO up{deduplication_id=d4eb4e63-5fa3-4f1a-b07c-e89b296deb93}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697:temperature aggregation=DAY
Dez 23 13:50:16 iotubuntu chirpstack[812]: 2022-12-23T13:50:16.716843Z INFO up{deduplication_id=d4eb4e63-5fa3-4f1a-b07c-e89b296deb93}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697:temperature aggregation=MONTH
Dez 23 13:50:16 iotubuntu chirpstack[812]: 2022-12-23T13:50:16.717007Z INFO up{deduplication_id=d4eb4e63-5fa3-4f1a-b07c-e89b296deb93}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697:humidity aggregation=HOUR
Dez 23 13:50:16 iotubuntu chirpstack[812]: 2022-12-23T13:50:16.717164Z INFO up{deduplication_id=d4eb4e63-5fa3-4f1a-b07c-e89b296deb93}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697:humidity aggregation=DAY
Dez 23 13:50:16 iotubuntu chirpstack[812]: 2022-12-23T13:50:16.717328Z INFO up{deduplication_id=d4eb4e63-5fa3-4f1a-b07c-e89b296deb93}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697:humidity aggregation=MONTH
Dez 23 13:50:16 iotubuntu chirpstack[812]: 2022-12-23T13:50:16.717517Z INFO up{deduplication_id=d4eb4e63-5fa3-4f1a-b07c-e89b296deb93}:data_up: chirpstack::storage::device_session: Device-session saved dev_eui=24e124136c278697 dev_addr=010d88f9
Dez 23 13:50:16 iotubuntu chirpstack[812]: 2022-12-23T13:50:16.717708Z INFO up{deduplication_id=d4eb4e63-5fa3-4f1a-b07c-e89b296deb93}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697 aggregation=HOUR
Dez 23 13:50:16 iotubuntu chirpstack[812]: 2022-12-23T13:50:16.717866Z INFO up{deduplication_id=d4eb4e63-5fa3-4f1a-b07c-e89b296deb93}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697 aggregation=DAY
Dez 23 13:50:16 iotubuntu chirpstack[812]: 2022-12-23T13:50:16.718040Z INFO up{deduplication_id=d4eb4e63-5fa3-4f1a-b07c-e89b296deb93}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697 aggregation=MONTH
Dez 23 13:50:28 iotubuntu chirpstack[812]: 2022-12-23T13:50:28.604004Z INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_name=“eu868” topic=“eu868/gateway/a840411fb1804150/event/stats” qos=0 json=true
Dez 23 13:50:28 iotubuntu chirpstack[812]: 2022-12-23T13:50:28.605658Z INFO stats{gateway_id=a840411fb1804150}: chirpstack::storage::gateway: Gateway state updated gateway_id=a840411fb1804150
Dez 23 13:50:28 iotubuntu chirpstack[812]: 2022-12-23T13:50:28.605831Z INFO stats{gateway_id=a840411fb1804150}: chirpstack::storage::metrics: Metrics saved name=gw:a840411fb1804150 aggregation=HOUR
Dez 23 13:50:28 iotubuntu chirpstack[812]: 2022-12-23T13:50:28.605931Z INFO stats{gateway_id=a840411fb1804150}: chirpstack::storage::metrics: Metrics saved name=gw:a840411fb1804150 aggregation=DAY
Dez 23 13:50:28 iotubuntu chirpstack[812]: 2022-12-23T13:50:28.606217Z INFO stats{gateway_id=a840411fb1804150}: chirpstack::storage::metrics: Metrics saved name=gw:a840411fb1804150 aggregation=MONTH
Dez 23 13:50:29 iotubuntu chirpstack[812]: 2022-12-23T13:50:29.624736Z INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_name=“eu868” topic=“eu868/gateway/a840411fb1804150/event/up” qos=0 json=true
Dez 23 13:50:29 iotubuntu chirpstack[812]: 2022-12-23T13:50:29.828870Z INFO up{deduplication_id=158a6537-8cc8-4e83-8bd5-fa82ad132e87}: chirpstack::uplink: Uplink received m_type=“UnconfirmedDataUp”
Dez 23 13:50:29 iotubuntu chirpstack[812]: 2022-12-23T13:50:29.828887Z DEBUG up{deduplication_id=158a6537-8cc8-4e83-8bd5-fa82ad132e87}: chirpstack::uplink: Updating gateway meta-data for uplink frame-set
Dez 23 13:50:29 iotubuntu chirpstack[812]: 2022-12-23T13:50:29.829500Z DEBUG up{deduplication_id=158a6537-8cc8-4e83-8bd5-fa82ad132e87}: chirpstack::uplink: Logging uplink frame to Redis Stream
Dez 23 13:50:29 iotubuntu chirpstack[812]: 2022-12-23T13:50:29.830188Z INFO up{deduplication_id=158a6537-8cc8-4e83-8bd5-fa82ad132e87}:data_up: chirpstack::storage::device_session: Device-session saved dev_eui=0018b24000007e31 dev_addr=01797b04
Dez 23 13:50:29 iotubuntu chirpstack[812]: 2022-12-23T13:50:29.833373Z INFO chirpstack::storage::device: Setting device lock dev_eui=0018b24000007e31
Dez 23 13:50:29 iotubuntu chirpstack[812]: 2022-12-23T13:50:29.834243Z INFO up{deduplication_id=158a6537-8cc8-4e83-8bd5-fa82ad132e87}:data_up: chirpstack::storage::device: Data-rate updated dev_eui=0018b24000007e31 dr=0
Dez 23 13:50:29 iotubuntu chirpstack[812]: 2022-12-23T13:50:29.834510Z INFO up{deduplication_id=158a6537-8cc8-4e83-8bd5-fa82ad132e87}:data_up: chirpstack::storage::device_gateway: Gateway rx-info saved dev_eui=0018b24000007e31
Dez 23 13:50:29 iotubuntu chirpstack[812]: 2022-12-23T13:50:29.852899Z INFO up{deduplication_id=158a6537-8cc8-4e83-8bd5-fa82ad132e87}:data_up: chirpstack::integration::mqtt: Publishing event topic=application/db5f86fe-0445-4223-acc3-1b9e61f8b4b6/device/0018b24000007e31/event/up
Dez 23 13:50:29 iotubuntu chirpstack[812]: 2022-12-23T13:50:29.854055Z INFO up{deduplication_id=158a6537-8cc8-4e83-8bd5-fa82ad132e87}:data_up: chirpstack::storage::device_session: Device-session saved dev_eui=0018b24000007e31 dev_addr=01797b04
Dez 23 13:50:29 iotubuntu chirpstack[812]: 2022-12-23T13:50:29.854296Z INFO up{deduplication_id=158a6537-8cc8-4e83-8bd5-fa82ad132e87}:data_up: chirpstack::storage::metrics: Metrics saved name=device:0018b24000007e31 aggregation=HOUR
Dez 23 13:50:29 iotubuntu chirpstack[812]: 2022-12-23T13:50:29.854478Z INFO up{deduplication_id=158a6537-8cc8-4e83-8bd5-fa82ad132e87}:data_up: chirpstack::storage::metrics: Metrics saved name=device:0018b24000007e31 aggregation=DAY
Dez 23 13:50:29 iotubuntu chirpstack[812]: 2022-12-23T13:50:29.854658Z INFO up{deduplication_id=158a6537-8cc8-4e83-8bd5-fa82ad132e87}:data_up: chirpstack::storage::metrics: Metrics saved name=device:0018b24000007e31 aggregation=MONTH
Dez 23 13:50:29 iotubuntu chirpstack[812]: 2022-12-23T13:50:29.855136Z INFO up{deduplication_id=158a6537-8cc8-4e83-8bd5-fa82ad132e87}:data_up: chirpstack::storage::mac_command: Pending mac-command block set dev_eui=0018b24000007e31 cid=LinkADRReq
Dez 23 13:50:29 iotubuntu chirpstack[812]: 2022-12-23T13:50:29.855316Z INFO up{deduplication_id=158a6537-8cc8-4e83-8bd5-fa82ad132e87}:data_up: chirpstack::storage::downlink_frame: Downlink-frame saved downlink_id=3770540385
Dez 23 13:50:29 iotubuntu chirpstack[812]: 2022-12-23T13:50:29.855507Z INFO up{deduplication_id=158a6537-8cc8-4e83-8bd5-fa82ad132e87}:data_up: chirpstack::storage::device_session: Device-session saved dev_eui=0018b24000007e31 dev_addr=01797b04
Dez 23 13:50:29 iotubuntu chirpstack[812]: 2022-12-23T13:50:29.855595Z INFO up{deduplication_id=158a6537-8cc8-4e83-8bd5-fa82ad132e87}:data_up: chirpstack::gateway::backend::mqtt: Sending downlink frame gateway_id=a840411fb1804150 topic=eu868/gateway/a840411fb1804150/command/down json=true
Dez 23 13:50:29 iotubuntu chirpstack[812]: 2022-12-23T13:50:29.929018Z INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_name=“eu868” topic=“eu868/gateway/a840411fb1804150/event/ack” qos=0 json=true
Dez 23 13:50:29 iotubuntu chirpstack[812]: 2022-12-23T13:50:29.929608Z INFO chirpstack::storage::device_session: Device-session saved dev_eui=0018b24000007e31 dev_addr=01797b04
Dez 23 13:50:29 iotubuntu chirpstack[812]: 2022-12-23T13:50:29.929725Z INFO chirpstack::downlink::tx_ack: Log downlink-frame for gateway gateway_id=a840411fb1804150
Dez 23 13:50:29 iotubuntu chirpstack[812]: 2022-12-23T13:50:29.929919Z INFO chirpstack::downlink::tx_ack: Log downlink-frame for device device_eui=0018b24000007e31
Dez 23 13:50:58 iotubuntu chirpstack[812]: 2022-12-23T13:50:58.630980Z INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_name=“eu868” topic=“eu868/gateway/a840411fb1804150/event/stats” qos=0 json=true
Dez 23 13:50:58 iotubuntu chirpstack[812]: 2022-12-23T13:50:58.632148Z INFO stats{gateway_id=a840411fb1804150}: chirpstack::storage::gateway: Gateway state updated gateway_id=a840411fb1804150
Dez 23 13:50:58 iotubuntu chirpstack[812]: 2022-12-23T13:50:58.632414Z INFO stats{gateway_id=a840411fb1804150}: chirpstack::storage::metrics: Metrics saved name=gw:a840411fb1804150 aggregation=HOUR
Dez 23 13:50:58 iotubuntu chirpstack[812]: 2022-12-23T13:50:58.632599Z INFO stats{gateway_id=a840411fb1804150}: chirpstack::storage::metrics: Metrics saved name=gw:a840411fb1804150 aggregation=DAY
Dez 23 13:50:58 iotubuntu chirpstack[812]: 2022-12-23T13:50:58.632772Z INFO stats{gateway_id=a840411fb1804150}: chirpstack::storage::metrics: Metrics saved name=gw:a840411fb1804150 aggregation=MONTH
Dez 23 13:51:16 iotubuntu chirpstack[812]: 2022-12-23T13:51:16.484936Z INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_name=“eu868” topic=“eu868/gateway/a840411fb1804150/event/up” qos=0 json=true
Dez 23 13:51:16 iotubuntu chirpstack[812]: 2022-12-23T13:51:16.689747Z INFO up{deduplication_id=5c66012e-3bfa-41ad-b6d8-0431fe15682f}: chirpstack::uplink: Uplink received m_type=“UnconfirmedDataUp”
Dez 23 13:51:16 iotubuntu chirpstack[812]: 2022-12-23T13:51:16.689766Z DEBUG up{deduplication_id=5c66012e-3bfa-41ad-b6d8-0431fe15682f}: chirpstack::uplink: Updating gateway meta-data for uplink frame-set
Dez 23 13:51:16 iotubuntu chirpstack[812]: 2022-12-23T13:51:16.690943Z DEBUG up{deduplication_id=5c66012e-3bfa-41ad-b6d8-0431fe15682f}: chirpstack::uplink: Logging uplink frame to Redis Stream
Dez 23 13:51:16 iotubuntu chirpstack[812]: 2022-12-23T13:51:16.691707Z INFO up{deduplication_id=5c66012e-3bfa-41ad-b6d8-0431fe15682f}:data_up: chirpstack::storage::device_session: Device-session saved dev_eui=24e124136c278697 dev_addr=010d88f9
Dez 23 13:51:16 iotubuntu chirpstack[812]: 2022-12-23T13:51:16.692499Z INFO chirpstack::storage::device: Setting device lock dev_eui=24e124136c278697
Dez 23 13:51:16 iotubuntu chirpstack[812]: 2022-12-23T13:51:16.693974Z INFO up{deduplication_id=5c66012e-3bfa-41ad-b6d8-0431fe15682f}:data_up: chirpstack::storage::device: Data-rate updated dev_eui=24e124136c278697 dr=5
Dez 23 13:51:16 iotubuntu chirpstack[812]: 2022-12-23T13:51:16.694570Z INFO up{deduplication_id=5c66012e-3bfa-41ad-b6d8-0431fe15682f}:data_up: chirpstack::storage::device_gateway: Gateway rx-info saved dev_eui=24e124136c278697
Dez 23 13:51:16 iotubuntu chirpstack[812]: 2022-12-23T13:51:16.699878Z INFO up{deduplication_id=5c66012e-3bfa-41ad-b6d8-0431fe15682f}:data_up: chirpstack::integration::mqtt: Publishing event topic=application/2dd5a192-ce47-4715-9d79-ae413dc1af91/device/24e124136c278697/event/up
Dez 23 13:51:16 iotubuntu chirpstack[812]: 2022-12-23T13:51:16.704247Z INFO up{deduplication_id=5c66012e-3bfa-41ad-b6d8-0431fe15682f}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697:humidity aggregation=HOUR
Dez 23 13:51:16 iotubuntu chirpstack[812]: 2022-12-23T13:51:16.704517Z INFO up{deduplication_id=5c66012e-3bfa-41ad-b6d8-0431fe15682f}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697:humidity aggregation=DAY
Dez 23 13:51:16 iotubuntu chirpstack[812]: 2022-12-23T13:51:16.704681Z INFO up{deduplication_id=5c66012e-3bfa-41ad-b6d8-0431fe15682f}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697:humidity aggregation=MONTH
Dez 23 13:51:16 iotubuntu chirpstack[812]: 2022-12-23T13:51:16.704840Z INFO up{deduplication_id=5c66012e-3bfa-41ad-b6d8-0431fe15682f}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697:temperature aggregation=HOUR
Dez 23 13:51:16 iotubuntu chirpstack[812]: 2022-12-23T13:51:16.704990Z INFO up{deduplication_id=5c66012e-3bfa-41ad-b6d8-0431fe15682f}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697:temperature aggregation=DAY
Dez 23 13:51:16 iotubuntu chirpstack[812]: 2022-12-23T13:51:16.705181Z INFO up{deduplication_id=5c66012e-3bfa-41ad-b6d8-0431fe15682f}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697:temperature aggregation=MONTH
Dez 23 13:51:16 iotubuntu chirpstack[812]: 2022-12-23T13:51:16.705374Z INFO up{deduplication_id=5c66012e-3bfa-41ad-b6d8-0431fe15682f}:data_up: chirpstack::storage::device_session: Device-session saved dev_eui=24e124136c278697 dev_addr=010d88f9
Dez 23 13:51:16 iotubuntu chirpstack[812]: 2022-12-23T13:51:16.705542Z INFO up{deduplication_id=5c66012e-3bfa-41ad-b6d8-0431fe15682f}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697 aggregation=HOUR
Dez 23 13:51:16 iotubuntu chirpstack[812]: 2022-12-23T13:51:16.705707Z INFO up{deduplication_id=5c66012e-3bfa-41ad-b6d8-0431fe15682f}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697 aggregation=DAY
Dez 23 13:51:16 iotubuntu chirpstack[812]: 2022-12-23T13:51:16.705858Z INFO up{deduplication_id=5c66012e-3bfa-41ad-b6d8-0431fe15682f}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697 aggregation=MONTH
Dez 23 13:51:28 iotubuntu chirpstack[812]: 2022-12-23T13:51:28.635818Z INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_name=“eu868” topic=“eu868/gateway/a840411fb1804150/event/stats” qos=0 json=true
Dez 23 13:51:28 iotubuntu chirpstack[812]: 2022-12-23T13:51:28.637250Z INFO stats{gateway_id=a840411fb1804150}: chirpstack::storage::gateway: Gateway state updated gateway_id=a840411fb1804150
Dez 23 13:51:28 iotubuntu chirpstack[812]: 2022-12-23T13:51:28.637575Z INFO stats{gateway_id=a840411fb1804150}: chirpstack::storage::metrics: Metrics saved name=gw:a840411fb1804150 aggregation=HOUR
Dez 23 13:51:28 iotubuntu chirpstack[812]: 2022-12-23T13:51:28.637769Z INFO stats{gateway_id=a840411fb1804150}: chirpstack::storage::metrics: Metrics saved name=gw:a840411fb1804150 aggregation=DAY
Dez 23 13:51:28 iotubuntu chirpstack[812]: 2022-12-23T13:51:28.637947Z INFO stats{gateway_id=a840411fb1804150}: chirpstack::storage::metrics: Metrics saved name=gw:a840411fb1804150 aggregation=MONTH
Dez 23 13:51:58 iotubuntu chirpstack[812]: 2022-12-23T13:51:58.637645Z INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_name=“eu868” topic=“eu868/gateway/a840411fb1804150/event/stats” qos=0 json=true
Dez 23 13:51:58 iotubuntu chirpstack[812]: 2022-12-23T13:51:58.639250Z INFO stats{gateway_id=a840411fb1804150}: chirpstack::storage::gateway: Gateway state updated gateway_id=a840411fb1804150
Dez 23 13:51:58 iotubuntu chirpstack[812]: 2022-12-23T13:51:58.639625Z INFO stats{gateway_id=a840411fb1804150}: chirpstack::storage::metrics: Metrics saved name=gw:a840411fb1804150 aggregation=HOUR
Dez 23 13:51:58 iotubuntu chirpstack[812]: 2022-12-23T13:51:58.639864Z INFO stats{gateway_id=a840411fb1804150}: chirpstack::storage::metrics: Metrics saved name=gw:a840411fb1804150 aggregation=DAY
Dez 23 13:51:58 iotubuntu chirpstack[812]: 2022-12-23T13:51:58.640030Z INFO stats{gateway_id=a840411fb1804150}: chirpstack::storage::metrics: Metrics saved name=gw:a840411fb1804150 aggregation=MONTH
Dez 23 13:52:16 iotubuntu chirpstack[812]: 2022-12-23T13:52:16.505209Z INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_name=“eu868” topic=“eu868/gateway/a840411fb1804150/event/up” qos=0 json=true
Dez 23 13:52:16 iotubuntu chirpstack[812]: 2022-12-23T13:52:16.709574Z INFO up{deduplication_id=3489ceb6-d9da-4b9f-806e-02c135d1c15c}: chirpstack::uplink: Uplink received m_type=“UnconfirmedDataUp”
Dez 23 13:52:16 iotubuntu chirpstack[812]: 2022-12-23T13:52:16.709590Z DEBUG up{deduplication_id=3489ceb6-d9da-4b9f-806e-02c135d1c15c}: chirpstack::uplink: Updating gateway meta-data for uplink frame-set
Dez 23 13:52:16 iotubuntu chirpstack[812]: 2022-12-23T13:52:16.710612Z DEBUG up{deduplication_id=3489ceb6-d9da-4b9f-806e-02c135d1c15c}: chirpstack::uplink: Logging uplink frame to Redis Stream
Dez 23 13:52:16 iotubuntu chirpstack[812]: 2022-12-23T13:52:16.711342Z INFO up{deduplication_id=3489ceb6-d9da-4b9f-806e-02c135d1c15c}:data_up: chirpstack::storage::device_session: Device-session saved dev_eui=24e124136c278697 dev_addr=010d88f9
Dez 23 13:52:16 iotubuntu chirpstack[812]: 2022-12-23T13:52:16.712140Z INFO chirpstack::storage::device: Setting device lock dev_eui=24e124136c278697
Dez 23 13:52:16 iotubuntu chirpstack[812]: 2022-12-23T13:52:16.713060Z INFO up{deduplication_id=3489ceb6-d9da-4b9f-806e-02c135d1c15c}:data_up: chirpstack::storage::device: Data-rate updated dev_eui=24e124136c278697 dr=5
Dez 23 13:52:16 iotubuntu chirpstack[812]: 2022-12-23T13:52:16.713357Z INFO up{deduplication_id=3489ceb6-d9da-4b9f-806e-02c135d1c15c}:data_up: chirpstack::storage::device_gateway: Gateway rx-info saved dev_eui=24e124136c278697
Dez 23 13:52:16 iotubuntu chirpstack[812]: 2022-12-23T13:52:16.717692Z INFO up{deduplication_id=3489ceb6-d9da-4b9f-806e-02c135d1c15c}:data_up: chirpstack::integration::mqtt: Publishing event topic=application/2dd5a192-ce47-4715-9d79-ae413dc1af91/device/24e124136c278697/event/up
Dez 23 13:52:16 iotubuntu chirpstack[812]: 2022-12-23T13:52:16.719841Z INFO up{deduplication_id=3489ceb6-d9da-4b9f-806e-02c135d1c15c}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697:temperature aggregation=HOUR
Dez 23 13:52:16 iotubuntu chirpstack[812]: 2022-12-23T13:52:16.720209Z INFO up{deduplication_id=3489ceb6-d9da-4b9f-806e-02c135d1c15c}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697:temperature aggregation=DAY
Dez 23 13:52:16 iotubuntu chirpstack[812]: 2022-12-23T13:52:16.720420Z INFO up{deduplication_id=3489ceb6-d9da-4b9f-806e-02c135d1c15c}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697:temperature aggregation=MONTH
Dez 23 13:52:16 iotubuntu chirpstack[812]: 2022-12-23T13:52:16.720591Z INFO up{deduplication_id=3489ceb6-d9da-4b9f-806e-02c135d1c15c}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697:humidity aggregation=HOUR
Dez 23 13:52:16 iotubuntu chirpstack[812]: 2022-12-23T13:52:16.720811Z INFO up{deduplication_id=3489ceb6-d9da-4b9f-806e-02c135d1c15c}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697:humidity aggregation=DAY
Dez 23 13:52:16 iotubuntu chirpstack[812]: 2022-12-23T13:52:16.721007Z INFO up{deduplication_id=3489ceb6-d9da-4b9f-806e-02c135d1c15c}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697:humidity aggregation=MONTH
Dez 23 13:52:16 iotubuntu chirpstack[812]: 2022-12-23T13:52:16.721223Z INFO up{deduplication_id=3489ceb6-d9da-4b9f-806e-02c135d1c15c}:data_up: chirpstack::storage::device_session: Device-session saved dev_eui=24e124136c278697 dev_addr=010d88f9
Dez 23 13:52:16 iotubuntu chirpstack[812]: 2022-12-23T13:52:16.721433Z INFO up{deduplication_id=3489ceb6-d9da-4b9f-806e-02c135d1c15c}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697 aggregation=HOUR
Dez 23 13:52:16 iotubuntu chirpstack[812]: 2022-12-23T13:52:16.721671Z INFO up{deduplication_id=3489ceb6-d9da-4b9f-806e-02c135d1c15c}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697 aggregation=DAY
Dez 23 13:52:16 iotubuntu chirpstack[812]: 2022-12-23T13:52:16.721881Z INFO up{deduplication_id=3489ceb6-d9da-4b9f-806e-02c135d1c15c}:data_up: chirpstack::storage::metrics: Metrics saved name=device:24e124136c278697 aggregation=MONTH
Dez 23 13:52:28 iotubuntu chirpstack[812]: 2022-12-23T13:52:28.641650Z INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_name=“eu868” topic=“eu868/gateway/a840411fb1804150/event/stats” qos=0 json=true
Dez 23 13:52:28 iotubuntu chirpstack[812]: 2022-12-23T13:52:28.642868Z INFO stats{gateway_id=a840411fb1804150}: chirpstack::storage::gateway: Gateway state updated gateway_id=a840411fb1804150
Dez 23 13:52:28 iotubuntu chirpstack[812]: 2022-12-23T13:52:28.643107Z INFO stats{gateway_id=a840411fb1804150}: chirpstack::storage::metrics: Metrics saved name=gw:a840411fb1804150 aggregation=HOUR
Dez 23 13:52:28 iotubuntu chirpstack[812]: 2022-12-23T13:52:28.643204Z INFO stats{gateway_id=a840411fb1804150}: chirpstack::storage::metrics: Metrics saved name=gw:a840411fb1804150 aggregation=DAY
Dez 23 13:52:28 iotubuntu chirpstack[812]: 2022-12-23T13:52:28.643437Z INFO stats{gateway_id=a840411fb1804150}: chirpstack::storage::metrics: Metrics saved name=gw:a840411fb1804150 aggregation=MONTH
bastian
December 31, 2022, 12:17pm
#8
Meanwhile I installed the proxy server because I needed several web applications and your script… now I can see events. Why that is… no idea
