Hi all,
recently I started to setup and use a Lite Gateway (Raspberry Pi + ic880a). I installed the provided image of the gateway OS. After some tries the concentrator was detected and I was able to run the gateway with the predefined configuration.
Today I wanted to add a timestamp with the fake_rx_time=true value. But it looks like the file modified with ‘sudo gateway-config’ (/etc/chirpstack-gateway-bridge/chirpstack-gateway-bridge.toml) is not the file that is later used as configuration file.
I added the fake_rx_time=true line here, but when running ‘sudo chirpstack-gateway-bridge configfile’ a completely different configuration file (where fake_rx_time is set to false) is printed out.
What am I doing wrong? From where is the configuration loaded?
Thanks in advance
Klaas
