I have stupid question, maybe for someone else…
I have this in my last lines in my .toml config file
# MQTT authentication.
[integration.mqtt.auth]
# Type defines the MQTT authentication type to use.
# Set this to the name of one of the sections below.
type="generic"
# Generic MQTT authentication.
server="tcp://127.0.0.1:1883"
username=""
password=""
And I want write/rewrite there this:
it is from azure config guide
type="azure_iot_hub"
[integration.mqtt.auth.azure_iot_hub]
device_connection_string="HostName=iot-hub-name.azure-devices.net;DeviceId=0102030405060708;SharedAccessKey=..."
Of course with my Connection string
Am I thinking right? Can rewrite it?
because I have no there this spesific settings, like in the Azure Guide.
