Hii @brocaar
how can we configure and testing the Passive roaming
feature?
- we have two servers
do we require NetId
for roaming?
Thanks
Hii @brocaar
feature?
do we require NetId
for roaming?
Thanks
A good start would be to study the LoRaWAN Backend Specs as it explains in details how Passive Roaming works and what steps are involved when a device is using Passive Roaming.
After that, please see the [[roaming.servers]]
configuration (https://www.chirpstack.io/network-server/install/config/). This is where you configure the roaming agreements between servers. You are correct that each network needs its own NetID.
