I’m wondering what the right approach is or if it’s possible to do all the configuration done in the WebUI via command line? The specific things I’m looking to configure:
I’m assuming you are using the Chirpstack Gateway OS if you want to configure concentratord, in that case you will want to use UCI commands to configure concentratord, as for 2 and 3 you will want to use the gRPC api.
