Just did a clean install of chirpstack on a raspberry pi 3 using [chirpstack-gateway-os-full-raspberrypi3-20200910132714.rootfs.wic.gz
Everything seems to be running and the GUI comes up fine but when I try to add a network server I get context deadline exceeded. I’ve seen lots of references to this in the forums but haven’t solved my issue yet. below is a snippet of the log that has some errors in it. Any help would be appreciated.
Sep 24 01:25:16 raspberrypi3 user.err chirpstack-gateway-bridge[480]: time=“2020-09-24T01:25:16Z” level=error msg=“backend/concentratord: event socket dial error” error="dial event api url error: zmq4: could not dial to “ipc:///tmp/concentratord_event”: dial unix /tmp/co
Sep 24 01:25:19 raspberrypi3 user.err chirpstack-gateway-bridge[480]: time=“2020-09-24T01:25:19Z” level=error msg=“backend/concentratord: event socket dial error” error="dial event api url error: zmq4: could not dial to “ipc:///tmp/concentratord_event”: dial unix /tmp/co
Sep 24 01:25:19 raspberrypi3 user.warn chirpstack-application-server[354]: time=“2020-09-24T01:25:19Z” level=warning msg=“creating insecure network-server client” server=“localhost:8000”
Sep 24 01:25:19 raspberrypi3 user.warn chirpstack-application-server[354]: time=“2020-09-24T01:25:19Z” level=warning msg="grpc: addrConn.createTransport failed to connect to {[::1]:8000 0 }. Err: connection error: desc = "transport: Error while dialing dial tcp
Sep 24 01:25:19 raspberrypi3 user.warn chirpstack-application-server[354]: time=“2020-09-24T01:25:19Z” level=warning msg="grpc: addrConn.createTransport failed to connect to {127.0.0.1:8000 0 }. Err: connection error: desc = "transport: Error while dialing dial
Sep 24 01:25:20 raspberrypi3 user.err chirpstack-application-server[354]: time=“2020-09-24T01:25:20Z” level=error msg=“finished unary call with code Unknown” ctx_id=b1e568ee-60c7-472c-bba5-3b70328dd2b4 error=“rpc error: code = Unknown desc = context deadline exceeded” grpc
Sep 24 01:25:23 raspberrypi3 user.err chirpstack-gateway-bridge[480]: time=“2020-09-24T01:25:23Z” level=error msg=“backend/concentratord: event socket dial error” error="dial event api url error: zmq4: could not dial to “ipc:///tmp/concentratord_event”: dial unix /tmp/co
Sep 24 01:25:26 raspberrypi3 user.err chirpstack-gateway-bridge[480]: time=“2020-09-24T01:25:26Z” level=error msg=“backend/concentratord: event socket dial error” error="dial event api url error: zmq4: could not dial to “ipc:///tmp/concentratord_event”: dial unix /tmp/co
Sep 24 01:25:30 raspberrypi3 user.err chirpstack-gateway-bridge[480]: time=“2020-09-24T01:25:30Z” level=error msg=“backend/concentratord: event socket dial error” error="dial event api url error: zmq4: could not dial to “ipc:///tmp/concentratord_event”: dial unix /tmp/co
Sep 24 01:25:33 raspberrypi3 user.err chirpstack-gateway-bridge[480]: time=“2020-09-24T01:25:33Z” level=error msg=“backend/concentratord: event socket dial error” error="dial event api url error: zmq4: could not dial to “ipc:///tmp/concentratord_event”: dial unix /tmp/co
Sep 24 01:25:37 raspberrypi3 user.err chirpstack-gateway-bridge[480]: time=“2020-09-24T01:25:37Z” level=error msg=“backend/concentratord: event socket dial error” error="dial event api url error: zmq4: could not dial to “ipc:///tmp/concentratord_event”: dial unix /tmp/co
Sep 24 01:25:40 raspberrypi3 user.err chirpstack-gateway-bridge[480]: time=“2020-09-24T01:25:40Z” level=error msg=“backend/concentratord: event socket dial error” error="dial event api url error: zmq4: could not dial to “ipc:///tmp/concentratord_event”: dial unix /tmp/co
