I am trying to use the custom javascript codec function, I have a working code in node however I am hitting a lot of js vm errors when I want to use the custom codec feature.
For example when I try to use Buffer, I get the following:
"js vm error: ReferenceError: 'Buffer' is not defined"
Would it be possible to know which functions are available on the js vm ?
Thank you,
