When I did my install on Ubuntu, the apps came with default config files. Makes sense.
In the documentation I saw that you can also generate new config files by doing: app configfile > filename.toml
When looking at the config file that comes from the install, versus the generated config files, they are very different in content.
So to the question…
Which config files are the “best” ones to use on a clean install - the ones that came with the app install or the ad hoc generated ones?
