sergorl
September 9, 2022, 1:43pm
1
I deployed chirpstack v4
and connected gateway working on 2400 Mhz (ISM2400 - LoRaWAN 2.4 GHz
), I see LORAWAN Frames from gateway:
|2022-09-09 16:32:55|ConfirmedDataUp|DevAddr: 260bdfad|
|2022-09-09 16:32:38|ConfirmedDataUp|DevAddr: 260bdfad|
|2022-09-09 16:30:47|ConfirmedDataUp|DevAddr: 260bdfad|
|2022-09-09 16:30:37|ConfirmedDataUp|DevAddr: 260bdfad|
|2022-09-09 16:28:54|ConfirmedDataUp|DevAddr: 260bdfad|
But my device 2g4 can’t be activated and doesn’t appear in chirpstack v4
P.S.: I check my device 2g4 and gateway 2g4 in ttn and both work perfectly: I see data from device in ttn console
P.S.2: in chirpstack v3
I also can’t activate device 2g4 and don’see device data.
brocaar
September 10, 2022, 1:21pm
2
Could you please add some additional context? I’m not sure how to read:
Do you have issues adding the device to ChirpStack v4? Or do you mean that the device doesn’t show as activated?
From the logs that you share, I only see ConfirmedDataUp, no join-request, which could explain why the device doesn’t show as activated in ChirpStack?
sergorl
September 11, 2022, 1:40pm
3
Dear @brocaar , I mean: the device doesn’t show as activated and I don’t see any device data, while in ttn I see frames from gateway and data from device.
Here is the pages of my device:
By the way in chirp v4 logs I see some error messages:
brocaar
September 12, 2022, 2:15pm
4
It looks like the uplink meta-data can’t be mapped to a data-rate. Do you know which parameters are being used? Any device-details that you can share?
No I faced a problem in chirpstack v3:
applicationID:"34"
applicationName:"miromico-2g4-sensor"
deviceName:"miromico-2g4-sensor"
devEUI:"10ce45fffe00abd2"
type:"OTAA"
error:"validate dev-nonce error"
fCnt:0
tags:
publishedAt:"2022-10-05T10:51:21.030051585Z"
I pushed button CLEARDEVNONCE
but id doesn’t help…
How to fix it?
