When I create a device profile and set the tags to it and then create a new device with this particular device-profile I don’t see the tags on the MQTT topic “application/X/devices/X/event/up”.
When I set the tags manually by the device configuration tab it works. But I want all the devices which are using a particular device-profile to have the same tags. Am I missing something here or is it a bug?
Let me think about this one. It is by design that only the device tags are exposed, but I can see an use-case to also include the device-profile tags, e.g. to expose device vendor related tags (vendor name, device model name, etc…).
I opened a pull request which will solve this issue. @brocaar do you need any disucssion on this? Are you not satisfied with the solution proposed? I would love to see at least the tags feature in the official release
Did you have a chance to look at including device profile tags in the event/up message yet as I really need that feature? I could get away with just the profile name, but the tag would be a much better option.
Thanks ever so much for everything you do for the community.
