I am trying to send a downlink message to a device in order to change it’s configuration. The vendor has supplied a spreadsheet to calculate the correct message to send.
I have successfully used the /api/devices/{device_queue_item.dev_eui}/queue API to POST the message and received HTTP 200 OK.
I can confirm I see it on the queue by calling the queue itself using /api/devices/{dev_eui}/queue
At this point I triggered an uplink message on my device and the queue cleared. I saw an ack from the device also.
I believe I have the process correct, however the device is not working the way it should so I’m starting to think I sent bad data to it.
The contents of the body was as follows
“deviceQueueItem”: {
“confirmed”: true,
“data”: “420000040500780000000405023C00000004050378000000040505803A09000405078051010001400501”,
“devEUI”: “244e7b0002000442”,
“fCnt”: 1,
“fPort”: 3
The data string “420000040500780000000405023C00000004050378000000040505803A09000405078051010001400501” was generated by the vendors spreadsheet. Do I need to encode this somehow before adding it to the DeviceQueueService?
Thanks.
