I’m a beginner to chirpstack.
I’m trying to send a firming from the chirpstack server to the node. With Class C i was able to recieve the data and ack to be true.
But when i run the device in class A and disabling the class B and class C in chirpstack, the downlink msg is sent soon after (1-2 sec) enqueuing the msg.
Also the msg is not being recieved at node.
What can be the issue?
Thanks in advance.
I had a similar problem, check your device profile and turn off Class C
You might also need to re-activate your device for the setting to propagate.
