I am trying downlink with “Enqueue” option from console and seeing this error.
chirpstack_1 | 2022-11-17T17:22:26.793450Z ERROR chirpstack::downlink::scheduler: Schedule next queue-item for device failed error=region_name does not exist in REGIONS
chirpstack_1 | 2022-11-17T17:22:28.810152Z ERROR chirpstack::downlink::scheduler: Schedule next queue-item for device failed error=region_name does not exist in REGIONS
chirpstack_1 | 2022-11-17T17:22:30.828207Z ERROR chirpstack::downlink::scheduler: Schedule next queue-item for device failed error=region_name does not exist in REGIONS
chirpstack_1 | 2022-11-17T17:22:32.849561Z ERROR chirpstack::downlink::scheduler: Schedule next queue-item for device failed error=region_name does not exist in REGIONS
I have deployed Chirpstack version 4 using docker-compose today. This is the docker-compose.yml
version: "3"
services:
chirpstack:
image: chirpstack/chirpstack:4.0.4
command: -c /etc/chirpstack
restart: unless-stopped
volumes:
- ./lorawan-devices:/opt/lorawan-devices
depends_on:
- postgres
- mosquitto
- redis
environment:
- MQTT_BROKER_HOST=mosquitto
- REDIS_HOST=redis
- POSTGRESQL_HOST=postgres
ports:
- 8080:8080
chirpstack-gateway-bridge-eu868:
image: chirpstack/chirpstack-gateway-bridge:4.0.1
ports:
- 1700:1700/udp
volumes:
depends_on:
- mosquitto
chirpstack-rest-api:
image: chirpstack/chirpstack-rest-api:4.0.4
command: --server chirpstack:8080 --bind 0.0.0.0:8090 --insecure
ports:
- 8090:8090
depends_on:
- chirpstack
postgres:
image: postgres:14-alpine
volumes:
environment:
- POSTGRES_PASSWORD=root
redis:
image: redis:7-alpine
volumes:
- redisdata:/data
mosquitto:
image: eclipse-mosquitto:2
ports:
- 1883:1883
volumes:
- ./configuration/mosquitto/mosquitto.conf:/mosquitto/config/mosquitto.conf
volumes:
postgresqldata:
redisdata:
I have verified the “chirpstack.toml” and dont see any errors there. This is the “chirpstack.toml” file
# Logging.
[logging]
# Log level.
level="info"
# PostgreSQL configuration.
[postgresql]
# PostgreSQL DSN.
# SSL mode options:
# * disable - no SSL
dsn="postgres://chirpstack:chirpstack@$POSTGRESQL_HOST/chirpstack?sslmode=disable"
# Max open connections.
# PostgreSQL connection pool.
max_open_connections=10
# Min idle connections.
min_idle_connections=0
# Redis configuration.
[redis]
servers=[
"redis://$REDIS_HOST/",
# TLS enabled.
tls_enabled=false
# Redis Cluster.
# instance.
cluster=false
[network]
net_id="000000"
# Enabled regions.
enabled_regions=[
"as923",
"as923_2",
"as923_3",
"as923_4",
"au915_0",
"cn470_10",
"cn779",
"eu433",
"eu868",
"in865",
"ism2400",
"kr920",
"ru864",
"us915_0",
"us915_1",
[api]
bind="0.0.0.0:8080"
# Secret.
# openssl rand -base64 32
secret="you-must-replace-this"
[integration]
enabled=["mqtt"]
[integration.mqtt]
server="tcp://$MQTT_BROKER_HOST:1883/"
json=true
# Event topic template.
event_topic="application/{{application_id}}/device/{{dev_eui}}/event/{{event}}"
# Command topic.
# This is the topic on which the MQTT subscribes for receiving (enqueue) commands.
command_topic="application/{{application_id}}/device/{{dev_eui}}/command/{{command}}"
Please let me know how to resolve the error.
Thanks.
Regards,
Harsha
