DR10 downlink wisGate error
At packet size 177 + 1 on DR10 500KHZ, I’m getting this error in the Rak wireless logs
Thu Aug 1 18:02:03 2024 user.warn lora_pkt_fwd[19944]: WARNING: [down] mismatch between .size and .data size once converter to binary
Where’s the best place to head in on this?
Which region are you using?
Usually, downlink doesn’t use BW 500KHz.
US915 923.3
I’m fairly certain most downlinks are 500khz according to things network chart anyway
May I have some photos to see downlinks use 500KHz?
CS and TNI use the same frequency plans as defined in LoRaWAN regional parameters.
I’m not sure what you may be getting at.
See here LoRaWAN Network - Technical Description - Telemetry2U.
Are you using RAK RUI3?
You may search the RUI3 source code for the error above.
Then you may have some hints.
It’s the gateway, and it’s closed source as far as I know. That particular error is found in the Semtech stack. I’ll see what Rak say
