I’m having strange duplicate DOWNLINKs coming as UPLINKs.
Background: there is an application server, two configured network servers, two configured gateways (currently just one for each network server) with the gateway bridge, three applications.
I don’t think this is an end-device issue because this happens with two different types of end devices (one is using OTAA and one is using ABP).
Here are the logs from the relevant time-frame (with some redactions for privacy):
Application and Network servers:
12:15:27 app-server chirpstack-application-server[1293]: time="2020-05-04T16:15:27+04:00" level=info msg="finished unary call with code OK" ctx_id=d71d0ada-5110-4534-a216-0208d4a03ee9 grpc.code=OK grpc.method=Get grpc.service=api.OrganizationService grpc.start_time="2020-05-04T16:15:27+04:00" grpc.time_ms=2.784 peer.address="127.0.0.1:54078" span.kind=server system=grpc
12:15:35 app-server chirpstack-network-server[861]: time="2020-05-04T16:15:35+04:00" level=info msg="gateway/mqtt: uplink frame received" gateway_id=gggggggggggg0001 uplink_id=83891bed-7afe-4d5d-8b7e-fb41169facaa
12:15:35 app-server chirpstack-network-server[861]: time="2020-05-04T16:15:35+04:00" level=info msg="uplink: frame(s) collected" ctx_id=24076a2f-41bb-4fb1-9183-10083e960e07 mtype=JoinRequest uplink_ids="[83891bed-7afe-4d5d-8b7e-fb41169facaa]"
12:15:35 app-server chirpstack-application-server[1293]: time="2020-05-04T16:15:35+04:00" level=info msg="backend/joinserver: request received" message_type=JoinReq receiver_id=0000000000000000 sender_id=zzzzzz transaction_id=2287457075
12:15:35 app-server chirpstack-application-server[1293]: time="2020-05-04T16:15:35+04:00" level=info msg="device-keys updated" ctx_id="<nil>" dev_eui=xxxxxxxxxxxx0001
12:15:35 app-server chirpstack-application-server[1293]: time="2020-05-04T16:15:35+04:00" level=info msg="backend/joinserver: sending response" message_type=JoinAns receiver_id=zzzzzz result_code=Success sender_id=0000000000000000 transaction_id=2287457075
12:15:35 app-server chirpstack-network-server[861]: time="2020-05-04T16:15:35+04:00" level=info msg="sent uplink meta-data to network-controller" ctx_id=24076a2f-41bb-4fb1-9183-10083e960e07 dev_eui=xxxxxxxxxxxx0001
12:15:35 app-server chirpstack-network-server[861]: time="2020-05-04T16:15:35+04:00" level=info msg="device-queue flushed" ctx_id=24076a2f-41bb-4fb1-9183-10083e960e07 dev_eui=xxxxxxxxxxxx0001
12:15:35 app-server chirpstack-network-server[861]: time="2020-05-04T16:15:35+04:00" level=info msg="device-session saved" ctx_id=24076a2f-41bb-4fb1-9183-10083e960e07 dev_addr=d43bbb43 dev_eui=xxxxxxxxxxxx0001
12:15:35 app-server chirpstack-network-server[861]: time="2020-05-04T16:15:35+04:00" level=info msg="device-activation created" ctx_id=24076a2f-41bb-4fb1-9183-10083e960e07 dev_eui=xxxxxxxxxxxx0001 id=41
12:15:35 app-server chirpstack-network-server[861]: time="2020-05-04T16:15:35+04:00" level=info msg="device updated" ctx_id=24076a2f-41bb-4fb1-9183-10083e960e07 dev_eui=xxxxxxxxxxxx0001
12:15:35 app-server chirpstack-network-server[861]: time="2020-05-04T16:15:35+04:00" level=info msg="gateway/mqtt: publishing gateway command" command=down downlink_id=24076a2f-41bb-4fb1-9183-10083e960e07 gateway_id=gggggggggggg0001 qos=0 topic=gateway/ru864/gggggggggggg0001/command/down
12:15:35 app-server chirpstack-network-server[861]: time="2020-05-04T16:15:35+04:00" level=info msg="downlink-frames saved" ctx_id=24076a2f-41bb-4fb1-9183-10083e960e07 token=3210
12:15:35 app-server chirpstack-network-server[861]: time="2020-05-04T16:15:35+04:00" level=info msg="backend/gateway: downlink tx acknowledgement received" downlink_id=24076a2f-41bb-4fb1-9183-10083e960e07 gateway_id=gggggggggggg0001
12:15:35 app-server chirpstack-network-server[861]: time="2020-05-04T16:15:35+04:00" level=info msg="sent downlink meta-data to network-controller" ctx_id=24076a2f-41bb-4fb1-9183-10083e960e07
12:15:41 app-server chirpstack-network-server[861]: time="2020-05-04T16:15:41+04:00" level=info msg="gateway/mqtt: uplink frame received" gateway_id=gggggggggggg0001 uplink_id=d9a0b06c-06ef-45dc-b5df-5bb9bc961bf5
12:15:42 app-server chirpstack-network-server[861]: time="2020-05-04T16:15:42+04:00" level=info msg="uplink: frame(s) collected" ctx_id=793df7ea-515a-4f5b-bb3b-f246dd36dd74 mtype=JoinAccept uplink_ids="[d9a0b06c-06ef-45dc-b5df-5bb9bc961bf5]"
12:15:43 app-server chirpstack-network-server[861]: time="2020-05-04T16:15:43+04:00" level=info msg="gateway/mqtt: uplink frame received" gateway_id=gggggggggggg0001 uplink_id=15b83ff1-dc9c-456b-9ecb-923a8b761764
12:15:43 app-server chirpstack-network-server[861]: time="2020-05-04T16:15:43+04:00" level=info msg="uplink: frame(s) collected" ctx_id=515b72eb-3a73-4f04-a711-46429b4ad20b mtype=UnconfirmedDataUp uplink_ids="[15b83ff1-dc9c-456b-9ecb-923a8b761764]"
12:15:43 app-server chirpstack-network-server[861]: time="2020-05-04T16:15:43+04:00" level=info msg="sent uplink meta-data to network-controller" ctx_id=515b72eb-3a73-4f04-a711-46429b4ad20b dev_eui=xxxxxxxxxxxx0001
12:15:43 app-server chirpstack-network-server[861]: time="2020-05-04T16:15:43+04:00" level=info msg="device gateway rx-info meta-data saved" ctx_id=515b72eb-3a73-4f04-a711-46429b4ad20b dev_eui=xxxxxxxxxxxx0001
12:15:43 app-server chirpstack-network-server[861]: time="2020-05-04T16:15:43+04:00" level=info msg="device-session saved" ctx_id=515b72eb-3a73-4f04-a711-46429b4ad20b dev_addr=d43bbb43 dev_eui=xxxxxxxxxxxx0001
12:15:43 app-server chirpstack-application-server[1293]: time="2020-05-04T16:15:43+04:00" level=info msg="device last-seen and dr updated" ctx_id=e82f83ab-680d-4bea-93c8-d4b97e0b0adb dev_eui=xxxxxxxxxxxx0001
12:15:43 app-server chirpstack-application-server[1293]: time="2020-05-04T16:15:43+04:00" level=info msg="device activation updated" ctx_id=e82f83ab-680d-4bea-93c8-d4b97e0b0adb dev_addr=d43bbb43 dev_eui=xxxxxxxxxxxx0001
12:15:43 app-server chirpstack-application-server[1293]: time="2020-05-04T16:15:43+04:00" level=info msg="finished unary call with code OK" ctx_id=e82f83ab-680d-4bea-93c8-d4b97e0b0adb grpc.code=OK grpc.method=HandleUplinkData grpc.request.deadline="2020-05-04T16:15:44+04:00" grpc.service=as.ApplicationServerService grpc.start_time="2020-05-04T16:15:43+04:00" grpc.time_ms=42.691 peer.address="127.0.0.1:54072" span.kind=server system=grpc
12:15:43 app-server chirpstack-network-server[861]: time="2020-05-04T16:15:43+04:00" level=info msg="finished client unary call" ctx_id=515b72eb-3a73-4f04-a711-46429b4ad20b grpc.code=OK grpc.ctx_id=e82f83ab-680d-4bea-93c8-d4b97e0b0adb grpc.duration=45.862677ms grpc.method=HandleUplinkData grpc.service=as.ApplicationServerService span.kind=client system=grpc
12:15:43 app-server chirpstack-application-server[1293]: time="2020-05-04T16:15:43+04:00" level=info msg="integration/mqtt: publishing message" ctx_id=e82f83ab-680d-4bea-93c8-d4b97e0b0adb qos=0 topic=application/4/device/xxxxxxxxxxxx0001/join
12:15:43 app-server chirpstack-application-server[1293]: time="2020-05-04T16:15:43+04:00" level=info msg="integration/mqtt: publishing message" ctx_id=e82f83ab-680d-4bea-93c8-d4b97e0b0adb qos=0 topic=application/4/device/xxxxxxxxxxxx0001/rx
12:15:47 app-server chirpstack-network-server[861]: time="2020-05-04T16:15:47+04:00" level=info msg="gateway/mqtt: gateway stats packet received" gateway_id=gggggggggggg0001 stats_id=5c031a32-c1f4-4e31-96ca-318dc54cbc34
12:15:47 app-server chirpstack-network-server[861]: time="2020-05-04T16:15:47+04:00" level=info msg="gateway updated" ctx_id=5c031a32-c1f4-4e31-96ca-318dc54cbc34 gateway_id=gggggggggggg0001
12:15:47 app-server chirpstack-application-server[1293]: time="2020-05-04T16:15:47+04:00" level=info msg="gateway updated" ctx_id=36f29f9c-9672-420b-a0f0-9aaeb8b1ba63 id=gggggggggggg0001 name=GGGGGG0001
12:15:47 app-server chirpstack-application-server[1293]: time="2020-05-04T16:15:47+04:00" level=info msg="metrics saved" aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=36f29f9c-9672-420b-a0f0-9aaeb8b1ba63 name="gw:gggggggggggg0001"
12:15:47 app-server chirpstack-application-server[1293]: time="2020-05-04T16:15:47+04:00" level=info msg="finished unary call with code OK" ctx_id=36f29f9c-9672-420b-a0f0-9aaeb8b1ba63 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time="2020-05-04T16:15:47+04:00" grpc.time_ms=17.908 peer.address="127.0.0.1:54072" span.kind=server system=grpc
12:15:47 app-server chirpstack-network-server[861]: time="2020-05-04T16:15:47+04:00" level=info msg="finished client unary call" ctx_id=5c031a32-c1f4-4e31-96ca-318dc54cbc34 grpc.code=OK grpc.ctx_id=36f29f9c-9672-420b-a0f0-9aaeb8b1ba63 grpc.duration=18.969047ms grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService span.kind=client system=grpc
12:16:13 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:13+04:00" level=info msg="gateway/mqtt: uplink frame received" gateway_id=gggggggggggg0001 uplink_id=d29d1c3c-ebf8-46e2-9ca7-1b39d89e7c3e
12:16:13 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:13+04:00" level=info msg="uplink: frame(s) collected" ctx_id=ec31d707-785b-4e89-9ac9-1f98e5fb5f24 mtype=UnconfirmedDataUp uplink_ids="[d29d1c3c-ebf8-46e2-9ca7-1b39d89e7c3e]"
12:16:13 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:13+04:00" level=info msg="sent uplink meta-data to network-controller" ctx_id=ec31d707-785b-4e89-9ac9-1f98e5fb5f24 dev_eui=xxxxxxxxxxxx0001
12:16:13 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:13+04:00" level=info msg="device gateway rx-info meta-data saved" ctx_id=ec31d707-785b-4e89-9ac9-1f98e5fb5f24 dev_eui=xxxxxxxxxxxx0001
12:16:13 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:13+04:00" level=info msg="device-session saved" ctx_id=ec31d707-785b-4e89-9ac9-1f98e5fb5f24 dev_addr=d43bbb43 dev_eui=xxxxxxxxxxxx0001
12:16:13 app-server chirpstack-application-server[1293]: time="2020-05-04T16:16:13+04:00" level=info msg="device last-seen and dr updated" ctx_id=dbccf4ff-ee64-46f9-9d2a-6b7363ca919c dev_eui=xxxxxxxxxxxx0001
12:16:13 app-server chirpstack-application-server[1293]: time="2020-05-04T16:16:13+04:00" level=info msg="finished unary call with code OK" ctx_id=dbccf4ff-ee64-46f9-9d2a-6b7363ca919c grpc.code=OK grpc.method=HandleUplinkData grpc.request.deadline="2020-05-04T16:16:14+04:00" grpc.service=as.ApplicationServerService grpc.start_time="2020-05-04T16:16:13+04:00" grpc.time_ms=28.225 peer.address="127.0.0.1:54072" span.kind=server system=grpc
12:16:13 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:13+04:00" level=info msg="finished client unary call" ctx_id=ec31d707-785b-4e89-9ac9-1f98e5fb5f24 grpc.code=OK grpc.ctx_id=dbccf4ff-ee64-46f9-9d2a-6b7363ca919c grpc.duration=30.110363ms grpc.method=HandleUplinkData grpc.service=as.ApplicationServerService span.kind=client system=grpc
12:16:13 app-server chirpstack-application-server[1293]: time="2020-05-04T16:16:13+04:00" level=info msg="integration/mqtt: publishing message" ctx_id=dbccf4ff-ee64-46f9-9d2a-6b7363ca919c qos=0 topic=application/4/device/xxxxxxxxxxxx0001/rx
12:16:13 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:13+04:00" level=info msg="gateway/mqtt: uplink frame received" gateway_id=gggggggggggg0001 uplink_id=ed63e9c0-c6b8-4df2-8226-0bed6553ebd6
12:16:14 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:14+04:00" level=info msg="uplink: frame(s) collected" ctx_id=df9e3f46-3456-480a-a35b-4bbf409bbb11 mtype=ConfirmedDataUp uplink_ids="[ed63e9c0-c6b8-4df2-8226-0bed6553ebd6]"
12:16:14 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:14+04:00" level=info msg="sent uplink meta-data to network-controller" ctx_id=df9e3f46-3456-480a-a35b-4bbf409bbb11 dev_eui=xxxxxxxxxxxxxx03
12:16:14 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:14+04:00" level=info msg="device gateway rx-info meta-data saved" ctx_id=df9e3f46-3456-480a-a35b-4bbf409bbb11 dev_eui=xxxxxxxxxxxxxx03
12:16:14 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:14+04:00" level=info msg="device-session saved" ctx_id=df9e3f46-3456-480a-a35b-4bbf409bbb11 dev_addr=70388802 dev_eui=xxxxxxxxxxxxxx03
12:16:14 app-server chirpstack-application-server[1293]: time="2020-05-04T16:16:14+04:00" level=info msg="device last-seen and dr updated" ctx_id=56eda4db-64eb-4a35-b815-1ef16d1ad0f6 dev_eui=xxxxxxxxxxxxxx03
12:16:14 app-server chirpstack-application-server[1293]: time="2020-05-04T16:16:14+04:00" level=info msg="finished unary call with code OK" ctx_id=56eda4db-64eb-4a35-b815-1ef16d1ad0f6 grpc.code=OK grpc.method=HandleUplinkData grpc.request.deadline="2020-05-04T16:16:15+04:00" grpc.service=as.ApplicationServerService grpc.start_time="2020-05-04T16:16:14+04:00" grpc.time_ms=18.081 peer.address="127.0.0.1:54072" span.kind=server system=grpc
12:16:14 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:14+04:00" level=info msg="finished client unary call" ctx_id=df9e3f46-3456-480a-a35b-4bbf409bbb11 grpc.code=OK grpc.ctx_id=56eda4db-64eb-4a35-b815-1ef16d1ad0f6 grpc.duration=19.799426ms grpc.method=HandleUplinkData grpc.service=as.ApplicationServerService span.kind=client system=grpc
12:16:14 app-server chirpstack-application-server[1293]: time="2020-05-04T16:16:14+04:00" level=info msg="integration/mqtt: publishing message" ctx_id=56eda4db-64eb-4a35-b815-1ef16d1ad0f6 qos=0 topic=application/1/device/xxxxxxxxxxxxxx03/rx
12:16:14 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:14+04:00" level=info msg="gateway/mqtt: publishing gateway command" command=down downlink_id=df9e3f46-3456-480a-a35b-4bbf409bbb11 gateway_id=gggggggggggg0001 qos=0 topic=gateway/ru864/gggggggggggg0001/command/down
12:16:14 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:14+04:00" level=info msg="downlink-frames saved" ctx_id=df9e3f46-3456-480a-a35b-4bbf409bbb11 token=57246
12:16:14 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:14+04:00" level=info msg="backend/gateway: downlink tx acknowledgement received" downlink_id=df9e3f46-3456-480a-a35b-4bbf409bbb11 gateway_id=gggggggggggg0001
12:16:14 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:14+04:00" level=info msg="sent downlink meta-data to network-controller" ctx_id=df9e3f46-3456-480a-a35b-4bbf409bbb11
12:16:15 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:15+04:00" level=info msg="gateway/mqtt: uplink frame received" gateway_id=gggggggggggg0001 uplink_id=d3020192-3f4f-49b7-995e-94dec0939138
12:16:16 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:16+04:00" level=info msg="uplink: frame(s) collected" ctx_id=c3af588a-8113-4b93-8700-0d7270f3b9c0 mtype=UnconfirmedDataDown uplink_ids="[d3020192-3f4f-49b7-995e-94dec0939138]"
12:16:17 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:17+04:00" level=info msg="gateway/mqtt: gateway stats packet received" gateway_id=gggggggggggg0001 stats_id=725bcac9-25bc-4188-941b-918ab11fa1ae
12:16:17 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:17+04:00" level=info msg="gateway updated" ctx_id=725bcac9-25bc-4188-941b-918ab11fa1ae gateway_id=gggggggggggg0001
12:16:17 app-server chirpstack-application-server[1293]: time="2020-05-04T16:16:17+04:00" level=info msg="gateway updated" ctx_id=b8774c72-ff84-491b-8158-c01d3324e769 id=gggggggggggg0001 name=GGGGGG0001
12:16:17 app-server chirpstack-application-server[1293]: time="2020-05-04T16:16:17+04:00" level=info msg="metrics saved" aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=b8774c72-ff84-491b-8158-c01d3324e769 name="gw:gggggggggggg0001"
12:16:17 app-server chirpstack-application-server[1293]: time="2020-05-04T16:16:17+04:00" level=info msg="finished unary call with code OK" ctx_id=b8774c72-ff84-491b-8158-c01d3324e769 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time="2020-05-04T16:16:17+04:00" grpc.time_ms=17.907 peer.address="127.0.0.1:54072" span.kind=server system=grpc
12:16:17 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:17+04:00" level=info msg="finished client unary call" ctx_id=725bcac9-25bc-4188-941b-918ab11fa1ae grpc.code=OK grpc.ctx_id=b8774c72-ff84-491b-8158-c01d3324e769 grpc.duration=18.909007ms grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService span.kind=client system=grpc
12:16:42 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:42+04:00" level=info msg="gateway/mqtt: uplink frame received" gateway_id=gggggggggggg0001 uplink_id=40d2c5a2-0118-4c40-9815-0f6e1f264f4d
12:16:42 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:42+04:00" level=info msg="uplink: frame(s) collected" ctx_id=b57d5f2a-df54-4272-bfad-56866c54e508 mtype=UnconfirmedDataUp uplink_ids="[40d2c5a2-0118-4c40-9815-0f6e1f264f4d]"
12:16:43 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:43+04:00" level=info msg="sent uplink meta-data to network-controller" ctx_id=b57d5f2a-df54-4272-bfad-56866c54e508 dev_eui=xxxxxxxxxxxx0001
12:16:43 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:43+04:00" level=info msg="device gateway rx-info meta-data saved" ctx_id=b57d5f2a-df54-4272-bfad-56866c54e508 dev_eui=xxxxxxxxxxxx0001
12:16:43 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:43+04:00" level=info msg="device-session saved" ctx_id=b57d5f2a-df54-4272-bfad-56866c54e508 dev_addr=d43bbb43 dev_eui=xxxxxxxxxxxx0001
12:16:43 app-server chirpstack-application-server[1293]: time="2020-05-04T16:16:43+04:00" level=info msg="device last-seen and dr updated" ctx_id=ff1d0845-6d93-4c16-a90c-7e9acc4d3080 dev_eui=xxxxxxxxxxxx0001
12:16:43 app-server chirpstack-application-server[1293]: time="2020-05-04T16:16:43+04:00" level=info msg="integration/mqtt: publishing message" ctx_id=ff1d0845-6d93-4c16-a90c-7e9acc4d3080 qos=0 topic=application/4/device/xxxxxxxxxxxx0001/rx
12:16:43 app-server chirpstack-application-server[1293]: time="2020-05-04T16:16:43+04:00" level=info msg="finished unary call with code OK" ctx_id=ff1d0845-6d93-4c16-a90c-7e9acc4d3080 grpc.code=OK grpc.method=HandleUplinkData grpc.request.deadline="2020-05-04T16:16:44+04:00" grpc.service=as.ApplicationServerService grpc.start_time="2020-05-04T16:16:43+04:00" grpc.time_ms=23.022 peer.address="127.0.0.1:54072" span.kind=server system=grpc
12:16:43 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:43+04:00" level=info msg="finished client unary call" ctx_id=b57d5f2a-df54-4272-bfad-56866c54e508 grpc.code=OK grpc.ctx_id=ff1d0845-6d93-4c16-a90c-7e9acc4d3080 grpc.duration=27.092559ms grpc.method=HandleUplinkData grpc.service=as.ApplicationServerService span.kind=client system=grpc
12:16:47 app-server chirpstack-network-server[861]: time="2020-05-04T16:16:47+04:00" level=info msg="gateway/mqtt: gateway stats packet received" gateway_id=gggggggggggg0001 stats_id=bed6cd07-6866-4b65-953d-bc8b73eb80e8
Gateway Bridge and Packet Forwarder
12:15:35 gateway chirpstack-gateway-bridge[599]: time="2020-05-04T12:15:35Z" level=info msg="integration/mqtt: publishing event" event=up qos=0 topic=gateway/ru864/gggggggggggg0001/event/up uplink_id=83891bed-7afe-4d5d-8b7e-fb41169facaa
12:15:35 gateway chirpstack-gateway-bridge[599]: time="2020-05-04T12:15:35Z" level=info msg="integration/mqtt: downlink frame received" downlink_id=24076a2f-41bb-4fb1-9183-10083e960e07 gateway_id=gggggggggggg0001
12:15:35 gateway chirpstack-gateway-bridge[599]: time="2020-05-04T12:15:35Z" level=info msg="integration/mqtt: publishing event" downlink_id=24076a2f-41bb-4fb1-9183-10083e960e07 event=ack qos=0 topic=gateway/ru864/gggggggggggg0001/event/ack
12:15:41 gateway chirpstack-gateway-bridge[599]: time="2020-05-04T12:15:41Z" level=info msg="integration/mqtt: publishing event" event=up qos=0 topic=gateway/ru864/gggggggggggg0001/event/up uplink_id=d9a0b06c-06ef-45dc-b5df-5bb9bc961bf5
12:15:43 gateway chirpstack-gateway-bridge[599]: time="2020-05-04T12:15:43Z" level=info msg="integration/mqtt: publishing event" event=up qos=0 topic=gateway/ru864/gggggggggggg0001/event/up uplink_id=15b83ff1-dc9c-456b-9ecb-923a8b761764
12:15:47 gateway lora_pkt_fwd[1140]: ### [UPSTREAM] ###
12:15:47 gateway lora_pkt_fwd[1140]: # RF packets received by concentrator: 7
12:15:47 gateway lora_pkt_fwd[1140]: # CRC_OK: 85.71%, CRC_FAIL: 14.29%, NO_CRC: 0.00%
12:15:47 gateway lora_pkt_fwd[1140]: # RF packets forwarded: 6 (84 bytes)
12:15:47 gateway lora_pkt_fwd[1140]: # PUSH_DATA datagrams sent: 7 (1295 bytes)
12:15:47 gateway lora_pkt_fwd[1140]: # PUSH_DATA acknowledged: 100.00%
12:15:47 gateway lora_pkt_fwd[1140]: ### [DOWNSTREAM] ###
12:15:47 gateway lora_pkt_fwd[1140]: # PULL_DATA sent: 3 (100.00% acknowledged)
12:15:47 gateway lora_pkt_fwd[1140]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
12:15:47 gateway lora_pkt_fwd[1140]: # RF packets sent to concentrator: 0 (0 bytes)
12:15:47 gateway lora_pkt_fwd[1140]: # TX errors: 0
12:15:47 gateway lora_pkt_fwd[1140]: # TX rejected (collision packet): 0.00% (req:3, rej:0)
12:15:47 gateway lora_pkt_fwd[1140]: # TX rejected (collision beacon): 0.00% (req:3, rej:0)
12:15:47 gateway lora_pkt_fwd[1140]: # TX rejected (too late): 0.00% (req:3, rej:0)
12:15:47 gateway lora_pkt_fwd[1140]: # TX rejected (too early): 0.00% (req:3, rej:0)
12:15:47 gateway lora_pkt_fwd[1140]: # BEACON queued: 0
12:15:47 gateway lora_pkt_fwd[1140]: # BEACON sent so far: 0
12:15:47 gateway lora_pkt_fwd[1140]: # BEACON rejected: 0
12:15:47 gateway lora_pkt_fwd[1140]: ### [JIT] ###
12:15:47 gateway lora_pkt_fwd[1140]: # SX1301 time (PPS): 662432699
12:15:47 gateway lora_pkt_fwd[1140]: src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
12:15:47 gateway lora_pkt_fwd[1140]: ### [GPS] ###
12:15:47 gateway lora_pkt_fwd[1140]: # Invalid time reference (age: 1588594517 sec)
12:15:47 gateway lora_pkt_fwd[1140]: # no valid GPS coordinates available yet
12:15:47 gateway lora_pkt_fwd[1140]: ##### END #####
12:15:47 gateway lora_pkt_fwd[1140]: JSON up: {"stat":{"time":"2020-05-04 12:15:17 GMT","rxnb":7,"rxok":6,"rxfw":6,"ackr":100.0,"dwnb":0,"txnb":0}}
12:15:47 gateway lora_pkt_fwd[1140]: INFO: [up] PUSH_ACK received in 0 ms
12:15:47 gateway lora_pkt_fwd[1140]: INFO: Received pkt from mote: D43B1C90 (fcnt=13)
12:15:47 gateway lora_pkt_fwd[1140]: JSON up: {"rxpk":[{"tmst":693654428,"chan":5,"rfch":1,"freq":868.900000,"stat":1,"modu":"LORA","datr":"SF12BW125","codr":"4/5","lsnr":-13.0,"rssi":-117,"size":14,"data":"=REDACTED-001="}]}
12:15:47 gateway lora_pkt_fwd[1140]: INFO: [up] PUSH_ACK received in 1 ms
12:15:47 gateway lora_pkt_fwd[1140]: INFO: Received pkt from mote: D43B1C90 (fcnt=14)
12:15:47 gateway lora_pkt_fwd[1140]: JSON up: {"rxpk":[{"tmst":697969044,"chan":6,"rfch":1,"freq":869.100000,"stat":1,"modu":"LORA","datr":"SF12BW125","codr":"4/5","lsnr":-12.5,"rssi":-115,"size":14,"data":"=REDACTED-002="}]}
12:15:47 gateway lora_pkt_fwd[1140]: INFO: [down] PULL_ACK received in 0 ms
12:15:47 gateway lora_pkt_fwd[1140]: INFO: Received pkt from mote: 00000000 (fcnt=0)
12:15:47 gateway lora_pkt_fwd[1140]: JSON up: {"rxpk":[{"tmst":710748636,"chan":5,"rfch":1,"freq":868.900000,"stat":1,"modu":"LORA","datr":"SF12BW125","codr":"4/5","lsnr":-15.2,"rssi":-115,"size":23,"data":"=REDACTED-003="}]}
12:15:47 gateway lora_pkt_fwd[1140]: INFO: [down] PULL_RESP received - token[138:12] :)
12:15:47 gateway lora_pkt_fwd[1140]: JSON down: {"txpk":{"imme":false,"rfch":0,"powe":14,"ant":0,"brd":0,"tmst":715748636,"freq":868.9,"modu":"LORA","datr":"SF12BW125","codr":"4/5","ipol":true,"size":17,"data":"=REDACTED-004="}}
12:15:47 gateway lora_pkt_fwd[1140]: INFO: tx_start_delay=1495 (1495.500000) - (1497, bw_delay=1.500000, notch_delay=0.000000)
12:15:47 gateway lora_pkt_fwd[1140]: INFO: Received pkt from mote: 44A87E8B (fcnt=60771)
12:15:47 gateway lora_pkt_fwd[1140]: JSON up: {"rxpk":[{"tmst":717067532,"chan":6,"rfch":1,"freq":869.100000,"stat":1,"modu":"LORA","datr":"SF12BW125","codr":"4/5","lsnr":2.5,"rssi":-111,"size":17,"data":"=REDACTED-004="}]}
12:15:47 gateway lora_pkt_fwd[1140]: INFO: Received pkt from mote: D43BBB43 (fcnt=1)
12:15:47 gateway lora_pkt_fwd[1140]: JSON up: {"rxpk":[{"tmst":718487548,"chan":5,"rfch":1,"freq":868.900000,"stat":1,"modu":"LORA","datr":"SF12BW125","codr":"4/5","lsnr":-12.8,"rssi":-117,"size":14,"data":"=REDACTED-005="}]}
12:15:47 gateway lora_pkt_fwd[1140]: INFO: Disabling GPS mode for concentrator's counter...
12:15:47 gateway lora_pkt_fwd[1140]: INFO: host/sx1301 time offset=(1588593824s:772088µs) - drift=41µs
12:15:47 gateway lora_pkt_fwd[1140]: INFO: Enabling GPS mode for concentrator's counter.
12:15:47 gateway lora_pkt_fwd[1140]: ##### 2020-05-04 12:15:47 GMT #####
12:15:47 gateway lora_pkt_fwd[1140]: # RF packets received by concentrator: 6
12:15:47 gateway lora_pkt_fwd[1140]: # CRC_OK: 83.33%, CRC_FAIL: 16.67%, NO_CRC: 0.00%
12:15:47 gateway lora_pkt_fwd[1140]: # RF packets forwarded: 5 (82 bytes)
12:15:47 gateway lora_pkt_fwd[1140]: # PUSH_DATA datagrams sent: 6 (1112 bytes)
12:15:47 gateway lora_pkt_fwd[1140]: # PULL_RESP(onse) datagrams received: 1 (194 bytes)
12:15:47 gateway lora_pkt_fwd[1140]: # RF packets sent to concentrator: 1 (17 bytes)
12:15:47 gateway lora_pkt_fwd[1140]: # TX rejected (collision packet): 0.00% (req:4, rej:0)
12:15:47 gateway lora_pkt_fwd[1140]: # TX rejected (collision beacon): 0.00% (req:4, rej:0)
12:15:47 gateway lora_pkt_fwd[1140]: # TX rejected (too late): 0.00% (req:4, rej:0)
12:15:47 gateway lora_pkt_fwd[1140]: # TX rejected (too early): 0.00% (req:4, rej:0)
12:15:47 gateway lora_pkt_fwd[1140]: # SX1301 time (PPS): 722432917
12:15:47 gateway lora_pkt_fwd[1140]: # Invalid time reference (age: 1588594547 sec)
12:15:47 gateway chirpstack-gateway-bridge[599]: time="2020-05-04T12:15:47Z" level=info msg="integration/mqtt: publishing event" event=stats qos=0 stats_id=5c031a32-c1f4-4e31-96ca-318dc54cbc34 topic=gateway/ru864/gggggggggggg0001/event/stats
12:16:13 gateway chirpstack-gateway-bridge[599]: time="2020-05-04T12:16:13Z" level=info msg="integration/mqtt: publishing event" event=up qos=0 topic=gateway/ru864/gggggggggggg0001/event/up uplink_id=d29d1c3c-ebf8-46e2-9ca7-1b39d89e7c3e
12:16:13 gateway chirpstack-gateway-bridge[599]: time="2020-05-04T12:16:13Z" level=info msg="integration/mqtt: publishing event" event=up qos=0 topic=gateway/ru864/gggggggggggg0001/event/up uplink_id=ed63e9c0-c6b8-4df2-8226-0bed6553ebd6
12:16:14 gateway chirpstack-gateway-bridge[599]: time="2020-05-04T12:16:14Z" level=info msg="integration/mqtt: downlink frame received" downlink_id=df9e3f46-3456-480a-a35b-4bbf409bbb11 gateway_id=gggggggggggg0001
12:16:14 gateway chirpstack-gateway-bridge[599]: time="2020-05-04T12:16:14Z" level=info msg="integration/mqtt: publishing event" downlink_id=df9e3f46-3456-480a-a35b-4bbf409bbb11 event=ack qos=0 topic=gateway/ru864/gggggggggggg0001/event/ack
12:16:15 gateway chirpstack-gateway-bridge[599]: time="2020-05-04T12:16:15Z" level=info msg="integration/mqtt: publishing event" event=up qos=0 topic=gateway/ru864/gggggggggggg0001/event/up uplink_id=d3020192-3f4f-49b7-995e-94dec0939138
12:16:17 gateway chirpstack-gateway-bridge[599]: time="2020-05-04T12:16:17Z" level=info msg="integration/mqtt: publishing event" event=stats qos=0 stats_id=725bcac9-25bc-4188-941b-918ab11fa1ae topic=gateway/ru864/gggggggggggg0001/event/stats
12:16:42 gateway chirpstack-gateway-bridge[599]: time="2020-05-04T12:16:42Z" level=info msg="integration/mqtt: publishing event" event=up qos=0 topic=gateway/ru864/gggggggggggg0001/event/up uplink_id=40d2c5a2-0118-4c40-9815-0f6e1f264f4d
12:16:47 gateway lora_pkt_fwd[1140]: JSON up: {"stat":{"time":"2020-05-04 12:15:47 GMT","rxnb":6,"rxok":5,"rxfw":5,"ackr":100.0,"dwnb":1,"txnb":1}}
