Error add extra channel to AU915-3
Hi Guy,
I add extra channel to region_au915_3.toml as below
# This file contains an example AU915 example (channels 24-31 + 67).
[[regions]]
  # Name is an use-defined identifier for this region.
  name="au915_3"
  # Common-name refers to the common-name of this region as defined by
  # the LoRa Alliance.
  common_name="AU915"
  # Gateway configuration.
  [regions.gateway]
    # Force gateways as private.
    # If enabled, gateways can only be used by devices under the same tenant.
    force_gws_private=false
    [regions.gateway.backend]
      # The enabled backend type.
      enabled="mqtt"
      # MQTT configuration.
        # Event topic template.
        event_topic="au915_3/gateway/+/event/+"
        # Command topic template.
        command_topic="au915_3/gateway/{{ gateway_id }}/command/{{ command }}"
        server="tcp://$MQTT_BROKER_HOST:1883"
        username=""
        password=""
        # Quality of service level
        # 0: at most once
        # 1: at least once
        # 2: exactly once
        qos=0
        # Clean session
        clean_session=false
        # Client ID
        # broker. A client id must be no longer than 23 characters. If left blank,
        # a random id will be generated by ChirpStack.
        client_id=""
        ca_cert=""
        tls_cert=""
        # TLS key file (optional)
        tls_key=""
    # Gateway channel configuration.
    # Note: this configuration is only used in case the gateway is using the
    # ChirpStack Concentratord daemon. In any other case, this configuration
    # is ignored.
    [[regions.gateway.channels]]
      frequency=920000000
      bandwidth=125000
      modulation="LORA"
      spreading_factors=[7, 8, 9, 10, 11, 12]
      frequency=920200000
      bandwidth=125000
      modulation="LORA"
      frequency=920400000
      bandwidth=125000
      modulation="LORA"
      frequency=920600000
      bandwidth=125000
      modulation="LORA"
      frequency=920800000
      bandwidth=125000
      modulation="LORA"
      frequency=921000000
      bandwidth=125000
      modulation="LORA"
      frequency=921200000
      bandwidth=125000
      modulation="LORA"
      frequency=921400000
      bandwidth=125000
      modulation="LORA"
      frequency=920700000
      bandwidth=500000
      modulation="LORA"
      spreading_factors=[8]
  # Region specific network configuration.
  [regions.network]
    # surrounded gateways.
    installation_margin=10
    # RX window (Class-A).
    # Set this to:
    # 0: RX1 / RX2
    # 1: RX1 only
    # 2: RX2 only
    rx_window=0
    # RX1 delay (1 - 15 seconds).
    rx1_delay=1
    # RX1 data-rate offset
    rx1_dr_offset=0
    # RX2 data-rate
    rx2_dr=8
    # RX2 frequency (Hz)
    rx2_frequency=923300000
    rx2_prefer_on_rx1_dr_lt=0
    # Prefer RX2 on link budget.
    # Downlink TX Power (dBm)
    # be used.
    downlink_tx_power=-1
    # ADR is disabled.
    adr_disabled=false
    # Minimum data-rate.
    min_dr=0
    # Maximum data-rate.
    max_dr=5
    # Enabled uplink channels.
    # Use this when ony a sub-set of the by default enabled channels are being
    # used. For example when only using the first 8 channels of the US band.
    # Note: when left blank / empty array, all channels will be enabled.
    enabled_uplink_channels=[24, 25, 26, 27, 28, 29, 30, 31, 67]
    # Rejoin-request configuration (LoRaWAN 1.1)
    [regions.network.rejoin_request]
      # Request devices to periodically send rejoin-requests.
      enabled=false
      # The device must send a rejoin-request type 0 at least every 2^(max_count_n + 4)
      # uplink messages. Valid values are 0 to 15.
      max_count_n=0
      # The device must send a rejoin-request type 0 at least every 2^(max_time_n + 10)
      # seconds. Valid values are 0 to 15.
      # 0  = roughly 17 minutes
      # 15 = about 1 year
      max_time_n=0
    # Class-B configuration.
    [regions.network.class_b]
      # Ping-slot data-rate.
      ping_slot_dr=8
      # Ping-slot frequency (Hz)
      # set this to 0 to use the default frequency plan for the configured region
      ping_slot_frequency=0
    **[[regions.network.extra_channels]]**
**    frequency=919600000**
**    min_dr=0**
**    max_dr=5**
**    [[regions.network.extra_channels]]**
**    frequency=919800000**
**    min_dr=0**
**    max_dr=5**
And after that, I start docker-compose but it show error like this:
chirpstack-docker-chirpstack-1                         | 2022-12-19T04:32:15.925410Z  INFO setup{common_name=AU915 region_name=au915_3}: chirpstack::region: Configuring region
chirpstack-docker-chirpstack-1                         | Error: Add channel
chirpstack-docker-chirpstack-1                         | Caused by:
chirpstack-docker-chirpstack-1                         |     User defined channels are not supported for this band
chirpstack-docker-chirpstack-rest-api-1                | Starting ChirpStack REST API server
Could you please help so I can add extra channel to AU915-3. Thank you!
Please see the error:
You can’t. The AU915 region uses a list of pre-configured channels. Please refer to the Regional Parameters Specifications for more information.
Hi @brocaar ,
Can I use this config to use some channels from other AU915-2, and avoid using some AU915-3 channel? So Chirpstack will operate at Custom frequencies.
  #enabled_uplink_channels=[24, 25, 26, 27, 28, 29, 30, 31, 67]
    enabled_uplink_channels=[22, 23, 24, 25, 26, 27, 28, 29, 67]
Sure. Please note that there aren’t really AU915-2, AU915-3, … regions. The configuration example just gives you the examples per block of 8, but there is nothing wrong with changing this / add new region config.
E.g. you might want to use a block of 16, 32 or even 64 channels. You can also offset your enabled_uplink_channels if you want, e.g. instead of starting at channel 24, start at 22 like in your example.
However, please make sure that you also configure these channels on your gateway and please be aware that there are some hardware constraints with regards to the available bandwidth of the gateway / the frequency span that the gateway can cover.
