I installed also ChirpStack on a raspberry debian buster (without Docker). Everything work for some days and today when i click on some items (gateway or device) on the web interface i get the error:
Error context deadline exceeded (code 2)
Can someone help me?
Have you had any success with this? I too am getting this bug. I got this bug even after reverting back to an image that was working completely on a different SD card. The pi worked for about 2 weeks and now it throws this exception when trying to access Gateway-profiles, service-profiles, device-profiles, gateways or applications
Hey all,
I just had this issue on my R-Pi using a somewhat suspect 8Gb SD card.
I solve it by just employing some house-keepingâŚ
I recommend you check the following:
Is your SD card good/fake etc?
verify all SD card image reading and writing sessions
clean your Ubuntu (clear old cache and logs files) to gain more disk space if you need it (my Chirpstack stated running quite slow and after I freed up space its back to fast UI loading etc)
make sure you have a large enough swap file setup
make back-up of your SD card image regularly.
Use a class 10 16 or 32Gb SD card
fit a CPU reset button on your R-Pi and only ever power up and down the R-Pi pressing the reset button first, only ever insert/remove the SD card when the power is off!
watch out for log files etc building up over time and reducing the memory available!
check for linux malware
Hi @brocaar, I have installed using apt but not docker. And since certificates are optional, I havenât provided any. How do I resolve this error?
I know this is a bit late, but Iâll comment in case it helps anyone else.
Try putting in the LAN or WAN IP address of the VM rather than âlocalhostâ.
If this doesnât fix it or your machine doesnât have an IP address, this may be a problem with the either,
- The VM firewall
- The hypervisor/VM hosting application (e.g. Iâve run into an issue with docker-ce not resolving hostnames between containers if not connecting to a WAN)
Good luck!
Hi, maybe my answer to another post can help some people for this issue. Here is the link :
I have got the same problem. I copy the virtual machine to new IP address and got âcontext deadline exceeded (code 2)â. I solve the problem when I change the correct address in tab âNetwork serversâ
I have installed in AWS EC2 ubuntu [no docker]and the same error rises. I tried different methods and finally given localhost:8000 and it works.
i am trying to do it with debian ubuntu , but still i am also getting he same error
Oct 04 10:59:37 mqtt.tihiitb.org chirpstack-application-server[176883]: time=â2024-10-04T10:59:37.307145303Zâ level=warning msg=âcreating insecure network-server clientâ server=â13.235.236.141:8000â
Oct 04 10:59:37 mqtt.tihiitb.org chirpstack-application-server[176883]: time=â2024-10-04T10:59:37.808203356Zâ level=warning msg=â[core] grpc: addrConn.createTransport failed to connect to {13.235.236.141:8000 13.235.236.141:8000 0 }. Err: connection error: desc = "transport: Error while dialing dial tcp 13.235.236.141:8000: operation was canceled". ReconnectingâŚâ
Oct 04 10:59:37 mqtt.tihiitb.org chirpstack-application-server[176883]: time=â2024-10-04T10:59:37.808435508Zâ level=error msg=âfinished unary call with code Unknownâ ctx_id=eee750b1-b3d8-4563-914d-a17ed562712b error=ârpc error: code = Unknown desc = context deadline exceededâ grpc.code=Unknown grpc.method=Create grpc.service=api.NetworkServerService grpc.start_time=â2024-10-04T10:59:37Zâ grpc.time_ms=502.887 peer.address=â127.0.0.1:58174â span.kind=server system=grpc
Oct 04 10:59:39 mqtt.tihiitb.org chirpstack-application-server[176883]: time=â2024-10-04T10:59:39.962837793Zâ level=warning msg=âcreating insecure network-server clientâ server=â13.235.236.141:8000â
this is the ip adress of my machine and my port 8080 is also working with this ip adress , but when i am trying to add a network server to this port , then it is showing context deadline exceeded , please support me to clear this problem
Please realize that you are trying to setup a ChirpStack version which is no longer supported. ChirpStack v4 contains many improvements and is a lot easier to setup.
