Error: NotFound desc = object does not exist” grpc.code=NotFound grpc.method=GetLastPing
I have installed one Gateway Lora on rpi wit IMST 880A Lora board.
I can’t configure it.
The output of ‘journalctl -u lora-app-server -f -n 10’ is
“feb 02 01:45:17 f360geo lora-app-server[2135]: time=“2018-02-02T01:45:17+01:00” level=info msg=“finished unary call with code NotFound” error=“rpc error: code = NotFound desc = object does not exist” grpc.code=NotFound grpc.method=GetLastPing grpc.service=api.Gateway grpc.start_time=“2018-02-02T01:45:17+01:00” grpc.time_ms=19.618 peer.address=”[::1]:41672" span.kind=server system=grpc"
any ideas?
Thank’s
This is just an informative error that you probably see when opening the gateway discovery tab in the web-interface. This only means that no ping has been received and the NotFound / 404 status is used by the web-interface that there is nothing to show :slight_smile:
