18:28:04 raspberrypi lora-gateway-bridge[3456]: time=“2019-03-21T18:28:04+01:00” level=info msg=“backend: publishing packet” qos=0 to
18:28:04 raspberrypi lora-gateway-bridge[3456]: time=“2019-03-21T18:28:04+01:00” level=info msg=“backend: downlink packet received” t
18:28:09 raspberrypi lora-gateway-bridge[3456]: time=“2019-03-21T18:28:09+01:00” level=error msg="gateway: could not handle packet: i
18:28:16 raspberrypi lora-gateway-bridge[3456]: time=“2019-03-21T18:28:16+01:00” level=info msg=“gateway: rxpk packet received” addr=
18:28:16 raspberrypi lora-gateway-bridge[3456]: time=“2019-03-21T18:28:16+01:00” level=info msg=“backend: publishing packet” qos=0 to
18:28:16 raspberrypi lora-gateway-bridge[3456]: time=“2019-03-21T18:28:16+01:00” level=info msg=“backend: downlink packet received” t
18:28:21 raspberrypi lora-gateway-bridge[3456]: time=“2019-03-21T18:28:21+01:00” level=error msg="gateway: could not handle packet: i
18:28:27 raspberrypi lora-gateway-bridge[3456]: time=“2019-03-21T18:28:27+01:00” level=info msg=“gateway: rxpk packet received” addr=
18:28:27 raspberrypi lora-gateway-bridge[3456]: time=“2019-03-21T18:28:27+01:00” level=info msg=“backend: publishing packet” qos=0 to
18:28:27 raspberrypi lora-gateway-bridge[3456]: time=“2019-03-21T18:28:27+01:00” level=info msg=“backend: downlink packet received” t
I’m closing this topic as I’m not sure what the question is.
