Hello, this is my first post on the forum i hope i will give you the right informations…
For a project i have to create a lorawan using chirpstack. This is impossible for me to launch the -application-server, i did every manipulations i’ve seen on tutorials, searching on forum and so on… I have a postgresql database witch seems connected with chirpstack-network-server i copy / past the line in application-server.toml file, generate a jwt key, try to reinstall application-server, try to drop and recreate database… nothing works
journalctl gives
févr. 18 15:26:34 raspberrypi systemd[1]: chirpstack-application-server.service: Service RestartSec=100ms expired, scheduling restart.
févr. 18 15:26:34 raspberrypi systemd[1]: chirpstack-application-server.service: Scheduled restart job, restart counter is at 4.
févr. 18 15:26:34 raspberrypi systemd[1]: Stopped ChirpStack Application Server.
févr. 18 15:26:34 raspberrypi systemd[1]: Started ChirpStack Application Server.
févr. 18 15:26:34 raspberrypi chirpstack-application-server[14307]: time=“2020-02-18T15:26:34+01:00” level=info msg=“starting ChirpStack Application Server” docs=“https://www.chirpstack.io/” version=3.8.0
févr. 18 15:26:34 raspberrypi chirpstack-application-server[14307]: time=“2020-02-18T15:26:34+01:00” level=info msg=“storage: setting up storage package”
févr. 18 15:26:34 raspberrypi chirpstack-application-server[14307]: time=“2020-02-18T15:26:34+01:00” level=info msg=“storage: setup metrics”
févr. 18 15:26:34 raspberrypi chirpstack-application-server[14307]: time=“2020-02-18T15:26:34+01:00” level=info msg=“storage: setting up Redis pool”
févr. 18 15:26:34 raspberrypi chirpstack-application-server[14307]: time=“2020-02-18T15:26:34+01:00” level=info msg=“storage: connecting to PostgreSQL database”
févr. 18 15:26:34 raspberrypi chirpstack-application-server[14307]: time=“2020-02-18T15:26:34+01:00” level=info msg=“storage: applying PostgreSQL data migrations”
févr. 18 15:26:34 raspberrypi chirpstack-application-server[14307]: time=“2020-02-18T15:26:34+01:00” level=fatal msg=“setup storage error: storage: applying PostgreSQL data migrations error: Unable to create migration plan because of 0002_node_frame_log.sql: unknown migration in database”
févr. 18 15:26:34 raspberrypi systemd[1]: chirpstack-application-server.service: Main process exited, code=exited, status=1/FAILURE
févr. 18 15:26:34 raspberrypi systemd[1]: chirpstack-application-server.service: Failed with result ‘exit-code’.
févr. 18 15:26:34 raspberrypi systemd[1]: chirpstack-application-server.service: Scheduled restart job, restart counter is at 5.
févr. 18 15:26:34 raspberrypi systemd[1]: chirpstack-application-server.service: Start request repeated too quickly.
févr. 18 15:26:34 raspberrypi systemd[1]: Failed to start ChirpStack Application Server.
[edit 1]
chirpstack-application-server configfile gives me a file configuration witch is diffrent than the one in /etc/…/…toml i am on
[edit 2]
When i try
pi@raspberrypi:~ $ sudo chirpstack-application-server --config /etc/chirpstack-application-server/chirpstack-application-server.toml
INFO[0000] starting ChirpStack Application Server docs=“https://www.chirpstack.io/” version=3.8.0
INFO[0000] storage: setting up storage package
INFO[0000] storage: setup metrics
INFO[0000] storage: setting up Redis pool
INFO[0000] storage: connecting to PostgreSQL database
INFO[0000] storage: applying PostgreSQL data migrations
FATA[0000] setup storage error: storage: applying PostgreSQL data migrations error: Unable to create migration plan because of 0002_node_frame_log.sql: unknown migration in database
but chirpstack-application-server still gives me a file configuration without the right database dsn.
I did a mistake seeing " ns and as " on db… i must use 2 diffrent databases…
