Hello everyone,
I’m trying to create the LoRa Server Raspberry Pi image, however I always get this message
Can someone please help me on how to avoid this authentication verification?
Thanks a lot!
Hello everyone,
Thanks a lot!
Could you provide us with the steps to reproduce this issue?
Hello, thanks for your answer.
Yes, At first I tried to create the image by using docker as suggested by the GitHub site pi-gen
sudo CONTINUE=1 ./build-docker.sh
However I got an message saying that there was an error while fetching some files from deb.debian.org, as shown in the following screen-shot.
So, I decided to do it by using the build.sh file. Everything goes well till the Stage 3 and then I got the error related to the authenticity of some packages.
Thank you very much for your help and time, I really appreciate it.
The error says there is an issue resolving deb.debian.org
. This usually indicates there is a networking issue. I recommend trying again ./build-docker.sh
and in case this error pops up again, try to solve the root issue instead of trying alternative methods.
Hello brocaar,
Thanks for your help As you’ve thought it was a networking use.
