I have a Kerlink Wirnet Station where I installed the Kerlink Common Packet Forwarder.
In the packet forwarder options I set the IP:1700 uplink and IP:1700 downlink of a machine where I installed LoRa Gateway Bridge, Lora Server, LoRa App Server.
When I use my device I almost always fail to receive downlink packets from the gateway, while when I try to use other gateways as RAK or Laird with the same LoRaServer chain on the same machine, it works perfectly.
Is the Kerlink Common Packet Forwarder compatible with LoRaServer ?
The Kerlink CPF should be compatible with the Semtech UDP packet-forwarder protocol. In the version I have tested, there was a bug but I believe this has been fixed in the meanwhile (I have not yet been able to re-test). Please make sure you are using the latest version of the CPF.
I’ve installed the Semtech Packet Forwarder and it works with no problems.
I think that the issue with the CPF has not been solved yet or somehow I am not able to configure it properly.
