root@VMLUBS011702:~# systemctl start loraserver
Failed to issue method call: Unit loraserver.service failed to load: No such file or directory. See system logs and ‘systemctl status loraserver.service’ for details.
Please take some effort to describe your issue. It is not clear at all:
- what you are asking, you’re just posting an error message
- how this can be re-produced (did you install the provided
.deb
package, and so, which version?) - what you tried yourself to solve this issue, there is even a hint in the error message
I am trying to install loraserver in ubuntu 14.04
Steps:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 1CE2AFD36DBCCA00
sudo echo "deb https://artifacts.loraserver.io/packages/2.x/deb stable main" | sudo tee /etc/apt/sources.list.d/loraserver.list
sudo apt-get update
sudo apt-get install lora-app-server
but i am facing issue while starting loraserver
service loraserver start
Error: loraserver: unrecognized service
Thanks
You’re installing lora-app-server
and trying to start loraserver
Please see https://www.loraserver.io/guides/ for some getting started guides.
I am reinstalling loraserver
and Lora-app-server
and i follow loraserver guides
but same problem
Install Log
apt-get install loraserver
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages were automatically installed and are no longer required:
linux-headers-4.2.0-27 linux-headers-4.2.0-27-generic
linux-image-4.2.0-27-generic linux-image-extra-4.2.0-27-generic
Use 'apt-get autoremove' to remove them.
The following NEW packages will be installed:
loraserver
0 upgraded, 1 newly installed, 0 to remove and 47 not upgraded.
Need to get 0 B/5,151 kB of archives.
After this operation, 14.8 MB of additional disk space will be used.
Selecting previously unselected package loraserver.
(Reading database ... 152598 files and directories currently installed.)
Preparing to unpack .../loraserver_2.2.0_amd64.deb ...
Unpacking loraserver (2.2.0) ...
Setting up loraserver (2.2.0) ...
Failed to issue method call: No such file or directory
Please help me…!
