Hi
Hope You all are doing well !
I am using RisingHF + RPI as a gateway and successfully seen the gateway last status on chirp stack in gateway detail section . I am using local server .And as a end node / device using nucleo with sx1262mb2xAS .
Now issue is that , i am unable to see the application / device data on chirp stack server .
I tried to trouble shoot the issue , by following the trouble shoot section of chirpstack server and find the following logs , which seems to be ok but unable to find the exact issue . Logs are as follows
When i run the " journalctl -f -n 100 -u chirpstack-network-server"
i got following response
21 22:36:38 muhammad-VirtualBox chirpstack-network-server[966]: time=“2020-07-21T22:36:38+05:00” level=info msg=“finished client unary call” ctx_id=64a21ac2-20b5-43f1-bc8d-3fc5e5707413 grpc.code=OK grpc.ctx_id=72538408-2cc1-4098-9bea-8887793e68f9 grpc.duration=12.058674ms grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService span.kind=client system=grpc
muhammad-VirtualBox chirpstack-network-server[966]: time=“2020-07-21T22:36:43+05:00” level=info msg=“finished unary call with code OK” ctx_id=945c53f0-5449-419f-8086-99aad536a846 grpc.code=OK grpc.method=GetGateway grpc.service=ns.NetworkServerService grpc.start_time=“2020-07-21T22:36:43+05:00” grpc.time_ms=4.168 peer.address=“127.0.0.1:38854” span.kind=server system=grpc
22:37:00 muhammad-VirtualBox chirpstack-network-server[966]: time=“2020-07-21T22:37:00+05:00” level=info msg=“gateway/mqtt: gateway stats packet received” gateway_id=b827ebfffe606395 stats_id=93db9d88-42e6-462d-a35d-90395b541e1a
21 22:37:00 muhammad-VirtualBox chirpstack-network-server[966]: time=“2020-07-21T22:37:00+05:00” level=info msg=“gateway updated” ctx_id=93db9d88-42e6-462d-a35d-90395b541e1a gateway_id=b827ebfffe606395
And when i run the following command
“journalctl -f -n 100 -u chirpstack-application-server”
i got the response as
muhammad-VirtualBox chirpstack-application-server[980]: time=“2020-07-21T22:39:30+05:00” level=info msg=“finished unary call with code OK” ctx_id=50e1c4bf-9c2f-4c08-a62f-7bc804f71d61 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2020-07-21T22:39:30+05:00” grpc.time_ms=3.788 peer.address=“127.0.0.1:40446” span.kind=server system=grpc
21 22:39:38 muhammad-VirtualBox chirpstack-application-server[980]: time=“2020-07-21T22:39:38+05:00” level=info msg=“gateway updated” ctx_id=8b70e8bb-4e79-45f3-9410-2967c2167424 id=b827ebfffe606395 name=IOTGATEWAY
21 22:39:38 muhammad-VirtualBox chirpstack-application-server[980]: time=“2020-07-21T22:39:38+05:00” level=info msg=“metrics saved” aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=8b70e8bb-4e79-45f3-9410-2967c2167424 name=“gw:b827ebfffe606395”
21 22:39:38 muhammad-VirtualBox chirpstack-application-server[980]: time=“2020-07-21T22:39:38+05:00” level=info msg=“finished unary call with code OK” ctx_id=8b70e8bb-4e79-45f3-9410-2967c2167424 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2020-07-21T22:39:38+05:00” grpc.time_ms=9.948 peer.address=“127.0.0.1:40446” span.kind=server system=grpc
Thanks for the help in advance .
