Gateway / Device statistics
In Lora App Server we can collect gatewy statistics based on the aggregated values sent by the gateway / packet-forwarder.
Is it possible to get the same on node level?
Is possible to export this statistics (gateways or node) to influxDB?
Yes, this is something I would consider for one of the next releases. Currently this is not supported yet.
Thank you for the answer. Just to confirm - currently it is not possible to collect node level stats and it is not possible to export data to InfluxDB. Is it correct?
To give a more specific answer, could you let me know what data you’re looking for? As https://www.loraserver.io/lora-app-server/integrate/sending-receiving/influxdb/ does already export some device data :slight_smile:
