This is my first time using loraserver.io, and I am getting the following (last line) error in the loraserver log.
Mar 15 17:51:12 raspberrypi loraserver[493]: time=“2018-03-15T17:51:12Z” level=info msg=“backend/gateway: rx packet received”
Mar 15 17:51:12 raspberrypi loraserver[493]: time=“2018-03-15T17:51:12Z” level=info msg=“rx info sent to network-controller” dev_eui=0072ab66f0dfb87e
Mar 15 17:51:12 raspberrypi loraserver[493]: time=“2018-03-15T17:51:12Z” level=info msg=“device updated” dev_eui=0072ab66f0dfb87e
Mar 15 17:51:12 raspberrypi loraserver[493]: time=“2018-03-15T17:51:12Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=UpdateDevice grpc.service=ns.NetworkServer grpc.start_time=“2018-03-15T17:51:12Z” grpc.time_ms=11.747 peer.address="[::1]:60982" span.kind=server system=grpc
Mar 15 17:51:12 raspberrypi lora-app-server[494]: time=“2018-03-15T17:51:12Z” level=info msg=“finished client unary call” grpc.code=OK grpc.method=UpdateDevice grpc.service=ns.NetworkServer grpc.time_ms=16.089 span.kind=client system=grpc
Mar 15 17:51:12 raspberrypi lora-app-server[494]: time=“2018-03-15T17:51:12Z” level=info msg=“device updated” dev_eui=0072ab66f0dfb87e
Mar 15 17:51:12 raspberrypi lora-app-server[494]: time=“2018-03-15T17:51:12Z” level=info msg=“handler/mqtt: publishing data-up payload” topic=application/1/node/0072ab66f0dfb87e/rx
Mar 15 17:51:13 raspberrypi lora-app-server[494]: time=“2018-03-15T17:51:13Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=HandleUplinkData grpc.service=as.ApplicationServer grpc.start_time=“2018-03-15T17:51:12Z” grpc.time_ms=396.794 peer.address=“127.0.0.1:44886” span.kind=server system=grpc
Mar 15 17:51:13 raspberrypi loraserver[493]: time=“2018-03-15T17:51:13Z” level=info msg=“finished client unary call” grpc.code=OK grpc.method=HandleUplinkData grpc.service=as.ApplicationServer grpc.time_ms=400.25 span.kind=client system=grpc
Mar 15 17:51:13 raspberrypi loraserver[493]: time=“2018-03-15T17:51:13Z” level=info msg=“device-session saved” dev_addr=07bb6d21 dev_eui=0072ab66f0dfb87e
Mar 15 17:51:13 raspberrypi loraserver[493]: time=“2018-03-15T17:51:13Z” level=error msg=“processing rx packet error: run uplink response flow error: get data down tx-info error: lorawan/band: invalid data-rate offset” data_base64="QCFtuweAqQABt3j7apX9MSI6nwQ="
Anyone know why this error appears? I am having problems with the downlink, so maybe this is the reason.
Thanks in advance!
