With the payload decoded by the codec function in the device-profile, measurement keys are automatically detected and stored in the device-profile measurements configuration tab (or you can add them yourself). The only thing you then need to do is select the measurement-kind and to give it a user-defined name, such that ChirpStack can aggregate the data for you. If no measurement-kind is selected, this feature is disabled (default behavior).
The purpose is not to turn ChirpStack into a complete dashboard solution and beat tools like Grafana, ThingsBoard etc… The scope of this feature is to provide simple visualization to help with initial testing and POCs
I was just wondering how you configure a gateway to be in a different region.
Whilst we are in EU, we have a partner in New Zealand. We added the gateway, but the region still says EU. It is not apparent where to change the region?
I managed to change the region, and I think I understand now. If one is to have multiple regions, do we simply need to create another gateway bridge and add it to the stack and then point the gateway at the associated bridge?
Hello!
Is there a way to disable frame counter validation for ABP devices? Although this is not good practice, it would be great for development and debugging.
i was part-way through an initial deployment on V3 and decided i’d cut my losses and start again in V4 rather than face imminent migration. It is so good!! And more intuitive. And so far no real rough edges.
