But that is also in error. I have checked and can’t seem to see where I am going wrong any help would be greatly apprecaited. Herewith my latest version.
by the way, this if for an Arad Water meter. I have looked everywhere but can’t find a decent codec anywhere and hence trying to get this to work
function Decode(fport, bytes, variables) {
console.log(bytes)
var decoded = {};
var frame_id = bytes[0];
decoded.frame_id = frame_id;
var firmware_version_1 = bytes[1];
decoded.firmware_version_1 = firmware_version_1;
var firmware_version_2 = bytes[2];
decoded.firmware_version_2 = firmware_version_2;
var eu_rssi = bytes[3];
decoded.eu_rssi = (256 - eu_rssi) * -1;
var last_stored_read = ((bytes[4] << 0) & 0xFF) + ((bytes[5] << 8) & 0xFFFF) + ((bytes[6] << 16) & 0xFFFFFF) + ((bytes[7] << 24) & 0xFFFFFFFF);
decoded.last_stored_read = last_stored_read;
var factor = bytes[8];
decoded.factor = factor;
var last_dl = (bytes[10] << 8) | bytes[9];
decoded.last_dl = last_dl;
var dl_interval = (bytes[12] << 8) | bytes[11];
decoded.dl_interval = dl_interval;
var alert_flags = (bytes[14] << 8) | bytes[13];
decoded.alert_flags = alert_flags;
var battery_level = (bytes[16] << 8) | bytes[15];
decoded.battery_level = battery_level / 1000;
var number_of_deltas = (bytes.length - 17) / 2;
decoded.number_of_deltas = number_of_deltas;
var water_volume = decoded.last_stored_read * decoded.factor
decoded.water_volume = water_volume;
// Call the decodeVolcanoFlags function to decode the volcano alert flags
var volcanoFlags = decodeVolcanoFlags(bytes, 15);
decoded = { ...decoded, ...volcanoFlags }; // Merge the decoded and volcanoFlags objects
return decoded;
// Decode the 2-byte bitmap starting from the specified offset
function decodeVolcanoFlags(bytes, offset) {
var flags = {};
var bitmap = (bytes[offset + 1] << 8) | bytes[offset];
flags.tamper = !!(bitmap & 0x01); // Bit 0 represents alert 1
flags.cut_wire = !!(bitmap & 0x02); // Bit 1 represents alert 2
flags.battery = !!(bitmap & 0x04); // Bit 2 represents alert 3
flags.leak = !!(bitmap & 0x08); // Bit 3 represents alert 4
flags.ccw = !!(bitmap & 0x10); // Bit 4 represents alert 5
flags.power_down = !!(bitmap & 0x20); // Bit 5 represents alert 6
flags.field_configuration = !!(bitmap & 0x40); // Bit 6 represents alert 7
flags.res = !!(bitmap & 0x80); // Bit 7 represents alert 8
flags.low_temp = !!(bitmap & 0x0100); // Bit 8 represents alert 9
flags.qmax = !!(bitmap & 0x0200); // Bit 9 represents alert 10
flags.poor_rf = !!(bitmap & 0x0400); // Bit 10 represents alert 11
flags.dl_active = !!(bitmap & 0x0800); // Bit 11 represents alert 12
flags.dl_mem_err = !!(bitmap & 0x1000); // Bit 12 represents alert 13
flags.dl_delta_of = !!(bitmap & 0x2000); // Bit 13 represents alert 14
flags.dl_delta_size = !!(bitmap & 0x4000); // Bit 14 represents alert 15
flags.res2 = !!(bitmap & 0x8000); // Bit 15 represents alert 16
return flags;
