How hard is it to connect a sensor directly to a relay gateway
It would be messy, especially to have them uplink through Chirpstack and appear in the UI. Although I’m sure it is possible, for example there is a LoRaWAN simulator out there to perform stress tests on your network, it creates “fake” Lorawan uplinks from different gateways, I believe it works by sending UDP packets to your gateway bridge that mimic real gateway uplinks.
The extra layer of complexity here is that you want to use the gateway mesh, which typically proxies traffic directly to/from concentratord, so to have the sensors on serial connections on the relay gateway, you would have to figure out how gateway mesh component interacts with concentratords API to pass along uplinks, then mimic that behavior with the incoming serial connections, translating them into whatever type of API request concentratord expects for Mesh packets.
You would also have to deal with how Chirpstack views these, you’d likely have to make these gateway sensors their own “device” in Chirpstack’s perspective, which means you would have to handle keys and encrypting the necessary data such that the gateway can send it over the mesh and the server can decrypt it, you’d likely want to have these sensors activated as ABP devices so you don’t have to handle the join process as well. But you’d have to pass the data to concentratord as if it was a fresh uplink that came from a device that is activated on your server.
Typically a mesh uplink goes:
  1. Concentratord receives uplink from a device (could be a gateway but lets keep it simple) and passes it to the Gateway Mesh component.
  2. The Gateway Mesh component wraps the packet in some additional mesh details, then passes it back to concentratord, telling concentratord that this is now a downlink (but it should broadcast it in uplink frequencies such that the next gateway will receive it).
  3. Concentratord then broadcasts the downlink (in uplink frequencies) to the next gateway.
You would have to skip steps 1 and 2, but transform the data from your local sensors into a similar format the gateway mesh component would. Then use concentratord’s API to send that message to the next gateway in the chain.
