this is my first project for learning
I connect UC1122 915is OK uplink ok
I use this coded
// N1: Payload Decoder
function Decoder(bytes, port) {
var decoded = {};
for (i = 0; i < bytes.length;) {
// BATTERY
if (bytes[i] == 0x01) {
decoded.battery = bytes[i + 2];
i += 3;
continue;
// GPIO
if (bytes[i] == 0x03) {
decoded.gpio1 = bytes[i + 2] === 0 ? "off" : "on";
i += 3;
continue;
if (bytes[i] == 0x04 && bytes[i + 1] !== 0xc8) {
decoded.gpio2 = bytes[i + 2] === 0 ? "off" : "on";
i += 3;
continue;
if (bytes[i] == 0x04 && bytes [i + 1] == 0xc8){
//Pulse Counter
decoded.counter = readUInt32LE(bytes.slice(i + 2, i + 6)) ;
i += 6;
continue;
// ADC
if (bytes[i] == 0x05) {
decoded.adc1 = {};
decoded.adc1.cur = readInt16LE(bytes.slice(i + 2, i + 4)) / 100;
decoded.adc1.min = readInt16LE(bytes.slice(i + 4, i + 6)) / 100;
decoded.adc1.max = readInt16LE(bytes.slice(i + 6, i + 8)) / 100;
decoded.adc1.avg = readInt16LE(bytes.slice(i + 8, i + 10)) / 100;
i += 10;
continue;
if (bytes[i] == 0x06) {
decoded.adc2 = {};
decoded.adc2.cur = readInt16LE(bytes.slice(i + 2, i + 4)) / 100;
decoded.adc2.min = readInt16LE(bytes.slice(i + 4, i + 6)) / 100;
decoded.adc2.max = readInt16LE(bytes.slice(i + 6, i + 8)) / 100;
decoded.adc2.avg = readInt16LE(bytes.slice(i + 8, i + 10)) / 100;
i += 10;
continue;
// MODBUS
if (bytes[i] == 0xFF && bytes[i + 1] == 0x0E) {
var chnId = bytes[i + 2];
var packageType = bytes[i + 3];
var dataType = packageType & 7;
var dataLength = packageType >> 3;
var chn = 'chn' + chnId;
switch (dataType) {
case 0:
decoded[chn] = bytes[i + 4] ? "on" : "off";
i += 5;
break;
case 1:
decoded[chn] = bytes[i + 4];
i += 5;
break;
case 2:
case 3:
decoded[chn] = readUInt16LE(bytes.slice(i + 4, i + 6));
i += 6;
break;
case 4:
case 6:
decoded[chn] = readUInt32LE(bytes.slice(i + 4, i + 8));
i += 8;
break;
case 5:
case 7:
decoded[chn] = readFloatLE(bytes.slice(i + 4, i + 8));
i += 8;
break;
return decoded;
- bytes to number
function readUInt8LE(bytes) {
return (bytes & 0xFF);
function readInt8LE(bytes) {
var ref = readUInt8LE(bytes);
return (ref > 0x7F) ? ref - 0x100 : ref;
function readUInt16LE(bytes) {
var value = (bytes[1] << 8) + bytes[0];
return (value & 0xFFFF);
function readInt16LE(bytes) {
var ref = readUInt16LE(bytes);
return (ref > 0x7FFF) ? ref - 0x10000 : ref;
function readUInt32LE(bytes) {
var value = (bytes[3] << 24) + (bytes[2] << 16) + (bytes[1] << 8) + bytes[0];
return (value & 0xFFFFFFFF);
function readInt32LE(bytes) {
var ref = readUInt32LE(bytes);
return (ref > 0x7FFFFFFF) ? ref - 0x100000000 : ref;
function readFloatLE(bytes) {
// JavaScript bitwise operators yield a 32 bits integer, not a float.
// Assume LSB (least significant byte first).
var bits = bytes[3] << 24 | bytes[2] << 16 | bytes[1] << 8 | bytes[0];
var sign = (bits >>> 31 === 0) ? 1.0 : -1.0;
var e = bits >>> 23 & 0xff;
var m = (e === 0) ? (bits & 0x7fffff) << 1 : (bits & 0x7fffff) | 0x800000;
var f = sign * m * Math.pow(2, e - 150);
return f;
but Codec error show Decode is not defined
