I have developed a lora gateway, and intergraded lora server in this device. This device is embed ARM and run a embed linux , It can work well.
Because I want let all debug information out to a log file, So start the lora-gateway-bridge use command:
./lora-gateway-bridge >>/tmp/lora-gateway-bridge.log &
The task can run exactly, but log file not create, and debug information still print in screen.
root@am335x-evm:~/lora/lora-gateway-bridge/build# ./lora-gateway-bridge >>/tmp/lora-gateway-bridge.log &
[4] 2259
root@am335x-evm:~/lora/lora-gateway-bridge/build# INFO[0000] starting LoRa Gateway Bridge docs="h=2.6.2-5-g8b51594
INFO[0000] backend: set max reconnect interval: 10m0s
INFO[0000] backend: TLS config is empty
INFO[0000] backend: connecting to mqtt broker server=“tcp://127.0.0.1:1883”
INFO[0000] gateway: starting gateway udp listener addr=“0.0.0.0:1700”
INFO[0000] backend: connected to mqtt broker
How can I let debug information to a log file?
