ktsakos
#1
Hello!
I have Ideetron’s LoRa Gateway Lorank8v1 and i would like to install on it the lora-gateway-bridge in order to send packets via MQTT .
This Gateway sends and receives normally UDP packets.It runs also a Debian 8(jessie) Linux OS.
Which instructions should i follow from the documentation in order to achieve this task?
brocaar
#2
This describes how to install LoRa Gateway Bridge:
https://docs.loraserver.io/lora-gateway-bridge/install/debian/
The first section describes which keys to change in your packet-forwarder configuration:
https://docs.loraserver.io/lora-gateway-bridge/install/config/
Hope this helps
