Hi. How to enable integration for only one application?
Example
application_1 = [‘mqtt’]
application_2 = [‘postgresql’]
this is not application integrations, this is whole chirpstack backend integration.
each app has own integration(s), which you can configure via web UI or REST API
I do not see mqtt and postgresql integration via API or web interface. How can I connect them exactly?
MQTT and PostgreSQL integration available in chirpstack-application-server.toml
configuration file
# Enabled integrations.
# Enabled integrations are enabled for all applications. Multiple
# integrations can be configured.
# Do not forget to configure the related configuration section below for
# the enabled integrations. Integrations that can be enabled are:
# * mqtt - MQTT broker
# * amqp - AMQP / RabbitMQ
# * aws_sns - AWS Simple Notification Service (SNS)
# * azure_service_bus - Azure Service-Bus
# * gcp_pub_sub - Google Cloud Pub/Sub
# * kafka - Kafka distributed streaming platform
# * postgresql - PostgreSQL database
enabled=["mqtt"]
# MQTT integration backend.
# Event topic template.
event_topic_template="application/{{ .ApplicationID }}/device/{{ .DevEUI }}/event/{{ .EventType }}"
# Command topic template.
command_topic_template="application/{{ .ApplicationID }}/device/{{ .DevEUI }}/command/{{ .CommandType }}"
# Retain events.
# The MQTT broker will store the last publised message, when retain events is set
# to true. When a MQTT client connects and subscribes, it will always receive the
# last published message.
retain_events=false
server="tcp://localhost:1883"
username=""
password=""
# Maximum interval that will be waited between reconnection attempts when connection is lost.
# Valid units are 'ms', 's', 'm', 'h'. Note that these values can be combined, e.g. '24h30m15s'.
max_reconnect_interval="1m0s"
# PostgreSQL database integration.
[application_server.integration.postgresql]
# PostgreSQL dsn (e.g.: postgres://user:password@hostname/database?sslmode=disable).
dsn=""
# PostgreSQL connection pool (0 = unlimited).
max_open_connections=0
# Max idle connections.
# This sets the max. number of idle connections in the PostgreSQL connection
# pool (0 = no idle connections are retained).
max_idle_connections=2
This will set up for all mqtt and postgresql.
How to configure mqtt for one application and configure postgresql for another application
Yes
This is not possible you can set MQTT or Postgre for all the application
